Results 1 to 19 of 19
    Established Member Two Rings Shaboink's Avatar
    Oct 03 2008
    Las Vegas, NV
    Gear Grinding! Please Help!!
    So I drive an 08 A4 2.0T and today while driving home I was at a red light, I go to leave and the car wouldn't go into first. I tried going from second to first but that didn't work, released and pressed the clutch back in and it sounded like it had grind (I didn't even push the shifter that hard). I had to shut the car off and turn it back on to finally get it in gear. It has done this a few times but never this bad and has never grind before. I've noticed it was hard to get into first or second sometimes but I figured it was because it was cold out or something. This is my first Audi so I'm a little worried, I bought it brand new and never expected to have too many problems (It's been to the dealership on warranty repairs three times already and it has less than 8000 miles). Any help would be greatly appreciated, I need to know what to tell my dealership this time.
    Oct 07 2008
    Michigan
    Re: Gear Grinding! Please Help!!
    sometimes my car is really hard to get into 1st gear if its real cold outside and i just started the car... no grinding ever though...hmm
    Veteran Member Four Rings viperdsa's Avatar
    Aug 28 2007
    Angry Gerbils
    west of the equator
    If I remember right there was a thread about this a little while ago. Sometimes when you come to a stop the teeth of the gears line up so they don't mesh (or somehthing to that affect). The next time you come to a stop and it won't go in first, put it in second then back in first, it sould work then. That might have been why it ground a little too.
    '06 Dolphin Gray A4 2.0T
    Motoza Tuned EFR
    Oct 03 2008
    Las Vegas, NV
    I had tried the second to first thing, so I'm a little lost as to what is going on with my car.
    Nov 05 2007
    Oregon
    be very calm and respectful when you bring the car in for evaluation. If your syncro(s) are bad, there's a chance they will try to blame your driving, which may or may not be the case at all (regardless of how bad they were designed). Is the problem recurring? Maybe have a tech drive the car, or you drive with them in the car, and see what they think. Just be warned, it is pretty much considered a wear item. You can burn out a clutch on day one of ownership, and they won't cover that either. You may be able to convince them, if they don't agree to cover it, that you're not shifting roughly by putting the car into first. Good luck, and keep us informed, but don't wait too long to take it in, and ask for some regional rep time and/or take it to another dealer if you don't get the response you're looking for the first time.
    Oct 03 2008
    Las Vegas, NV
    Thanks for all the info. I'm going to wait a week to make sure it is a real problem, plus I will actually have time to take it to the dealership. It just seemed so odd to me that a car would grind with the clutch fully depressed. I'm hoping they're are understanding, they seem to be before but I have a feeling the service manager there is getting annoyed with me. I've already had a radio replaced, tpms sensor issues, as well as the most recent a low oil warning (I suspect the tech didn't put enough in, because there were no signs of leakage at all.) Hopefully it isn't the syncro's because I sure as hell can't afford to replace those.
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Definitely sounds like a synchro if it's grinding and the clutch is fully depressed. The same thing happened to me, although it was my third gear. Long story short, my dealership denied replacing it under warranty because I have an intake and diverter valve on my car. I am actually supposed to receive a call from a guy from Audi of America today or tomorrow with a verdict on if they are going to honor my warranty. My guess is that if you don't have any modifications done to your car, you really shouldn't have any problems getting them to replace your synchro under warranty. Especially since you only have 8k miles on the car. If they deny you warranty work, don't take no for an answer!
    I don't recall ever hearing anyone having this problem with their first gear. I have only heard of people having a hard time getting the car to go into first. Usually just letting off the clutch and pushing it back in or going into second and then first will solve that problem... Have you ever tried to put the car into first when rolling over 10-15 mph?
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    all i could think about when i read the thread title was:
    Veteran Member Three Rings scoobycarolan's Avatar
    Nov 02 2007
    Albany, NY
    Nope. This is the same with my car and tons others. It's the slop and tight design of the synchos. Search the forums for "notchy" you'll get quite a lot of hits. What works for me is to put the car in 3rd. Push the shifter to the left (this is the slop). Now gently bring it down and around to first so that you're hugging the gate and your on the right hand side of first. I bought my car last january with 15 miles on it and this was happening that day. The dealer told me it was normal. I bought a JHM short shifter which reduced the amount of slop. Go to www.audishifter.com and watch the videos. Jay tears a six speed tranny down and explains it all.
    Scooby Carolan: Massive Audio
    2008 Ibis A4 2.0T
    Titanium | S-Line | Sport (20% Tint / Debadged)
    APR 93 octane / JHM SS / EVOms DV / Eurojet PCV
    Koni FSD / Eibach Pro-Kit / RS4 Sway
    **Join the Upstate NY Regional Group!**
    Oct 07 2008
    Michigan
    kind of off topic but cant resting your hand on the shift knob continuously over time f*ck up your synchros?
    Veteran Member Four Rings pOrKcHoP07's Avatar
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    ^^ yea don't rest your hand on the shift knob after your in gear. The only time your hand should be on it is to shift.
    2003 Audi A4 1.8T Quattro
    AKA: masterforu2nv
    Current Mods:
    Debadge. 3000k DDM Tuning HID Fogs. 5000k DDM Tuning HID Kit. AWE Exhaust. Window/Fog Vag Mod. VMAXX Coilovers. Enkei Raijins. Adam Rotors. Hawk HPS Pads. SS Brake Lines. RAI Testpipe. Racetec FMIC. JHM SS. Motoza Stage 1 Chip.Evolution Racewerks TIP.
    Senior Member Two Rings coolguy32's Avatar
    Aug 29 2008
    Rancho Cucamonga,California
    i do notice 2nd is a little tough to get into when it's cold....after it warms up, it feels normal......
    Oct 03 2008
    Las Vegas, NV
    Quote Originally Posted by Glassnpowder98 View Post
    I kinda assumed that it was gonna be the syncro's I just wanted to check, I haven't touched my car with the exception of tint (which the dealer did anyway) and a little vinyl here or there so I don't see anyway they could try and deny for mods. I wouldn't even expect them to because they are a stasis dealership and I know countless guys going in their chipped, where as long as it is in stock mode the techs don't care.
    Hopefully for you it all works out and they do cover it.
    I had tried all the standard responses to it not going because I had read the threads where a few guys were having problems before. Nothing solved it but fully shutting off and turning it back on. I've never pushed it into first while going that fast, the car gets babied and all the miles are highway.
    Jun 02 2007
    2004 cbr600 rr 1988 16V scirocco
    vancouver
    yeah the tranny is designed to not go onto first if you're going over a certain speed.....don't try to force it
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    I have noticed, and I am looking to confirm this, My car will not go into first gear unless I am below 5mph. So when I am rolling in traffic say anything over 5mph i have to be in second, i can not get it to go into first. Is anyone experiencing this?
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded (Gone)
    2019 S4, Glacier White - Prestige
    Established Member Two Rings a4 steve's Avatar
    Dec 02 2008
    06 Evo 9
    New Jersey/ Michigan
    the a4 tranny isint that good lets face it my tranny is so fucked up when i put it in 4th or 6th there was nothing there. and on top of that my 3rd gear grinds so i whent to audi and i told them about the problem and those ******s at the stealership sed that audi dosent warranty the tranny i was like wtf so i spent almost 4k on a lighter flywheel a stage 2 cultch and a rebuild tranny
    Debadged, Filler Plate, 3 Piece Spoiler, Carbonio CAI, Yellow Fog, REVO stage 2, AWE Exhaust, ATP test pipe, Forge DV,piaa yellow fogs,black out trim, black out grill with filler, lighter flywheel, stage 2 clutch, OZ Ultraleggera, KW V3 coils,eyelids, cupra lip AWE boost gauge
    costom turbo inlet pipe for sale
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Quote Originally Posted by nick71692 View Post
    yeah, that's normal with most modern manual cars.
    Oct 03 2008
    Las Vegas, NV
    Ok so since the grinding incident it hasn't happened again. It doesn't get stuck, it's very weird but the transmission feels like it did on day one. Is there something I should be worried about. I have a feeling the issue is with the cold, it has been kinda cold around here lately especially late at night when I had the issue.
    Mar 18 2007
    Quote Originally Posted by a4 steve View Post
    congradulations, thats what happens when you go audi. Im glad my experience was young and fast.
    APR 100 Oct / Ecode Testpipe/ Forge DV/H&R Springs/Kerscher CF Splitter/
