Results 1 to 10 of 10
    Dec 03 2008
    chino ca
    INtake manifold question
    im new on here and im looking to get a new intake manifold
    any inputs on which on i should get
    i have a k04 but am building to big turbo
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: INtake manifold question
    it depends on what turbo you are going with.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 03 2008
    chino ca
    most likely a GT2871R - 743347-1
    but for my k04 right now what can i go with
    Jun 04 2007
    Austin/DFW, TX
    i wouldnt bother getting a manifold for your k04 only to have to possibly change it down the road. If you get an eliminator, you can get like an ATP or something
    My 5-Speed Swap DIY
    - B6 USP
    Feb 27 2005
    North Wales, PA
    hes talking about intake manifolds.
    Jun 04 2007
    Austin/DFW, TX
    oh shit!
    hahaha, its late, im out of it.
    OP disregard my posts!
    My 5-Speed Swap DIY
    - B6 USP
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    OEM intake manifold is fine for your power levels... just leave it alone
    Dec 03 2008
    chino ca
    hahahha its kool bro
    Dec 05 2007
    If you want to upgrade your IM, get a High Flow one. With a k04, you will not see any gains. But if you plan on going BT or BAT, then you will see gains then. So, to get a High Flow Intake Manifold is basically a waste of money at your current stage. But it is a good upgrade for your future build. There are a couple people that have sell them. 034 sells them and a couple other tuners like Dahlback. Or give Mike Hood a PM. He can help you out. http://www.audizine.com/forum/member.php?u=2716
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Port it out. Sure it takes some time, but I noticed a difference even on my K03s.
    Jim (onemoremile) ported the runner ends out a bit as well, I don't know where his pics are right now. He noted an increase in fuel mileage, which is always a good sign of improvement as well. He's running the K04 as well.
    Here's mine. There's a "big" casting lip all around the inside of the throttle body neck, I removed it. I also ported out the throttle body itself. You can upgrade to an OBD2 VR6 TB iirc, and you should be able to notice on the BT, no promises on the K04.
    Here's why you want to upgrade the throttle body if you're looking for power, the throttle plate it tiny.
