If anyone can help figure out this dreaded red warning light and why it intermittently comes on and off that would be a big help. My local dealership has seen my car 3 times this week diagnosing this issue, the first time I brought it in they found that the oil pressure sensor to be faulty after running a diagnostic test and compression check. The part was replaced ($45) with labour ($119 / hr). I am out of warranty (4 years or 80,000kms), so I had to pay for that up front.
The light still came on so I brought it back a second time, and demanded that I get refunded at least partially for the original work since they didn't solve the problem. This second time around the service manager decided that all work would be covered under a "good will" warranty, so all subsequent work / parts related to the oil pressure warning would be at no cost to me. At this point the work involved was this:
Cause: Pressured test system. Found after running oil pressure started to drop below spec. Removed valve cover. Inspected all bearing caps for cams. All OK.
Correction: Performed oil sludge TSB. Replaced all necess. hoses & parts. Rechecked oil pressure & roadtested vehicle OK.
Parts replaced:
06A-103-213-F - TUBE
06A-103-213-G - TUBE
06A-103-213-T - TUBE
06A-103-217-AA - VENTHOSE
06A-103-224-C - VENTHOSE
06A-103-245 - VALVE
06A-103-493-M - HOSE
06A-115-251 - PIPE
N-028-222-2 - WASHER
N-904-673-01 - SEAL
06A-103-247 - HOUSING
06A-129-101-D - VALVE
06A-121-142-A - SPRING
058-133-753-D - PUMP
058-145-757-A - GASKET
N-100-980-01 - CLIP
N-101-662-01 - CLIP
N-101-976-01 - CLIP
N-102-555-01 - CLIP
N-102-556-01 - CLIP
06B-103-221-F - VENTHOSE
068-103-221-G - VENTHOSE
06B-103-493-M - HOSE
D-176-404-A2 - SEALANT
06B-145-771-P - OIL PIPE
N-013-851-4 - WASHER
N-904-096-01 - CLIP
N-904-119-01 - CLIP
N-905-618-01 - CLIP
N-904-119-01 - CLIP
N-905-618-01 - CLIP
068-115-561-B - OIL FILTER
ZVP-000-540 - 5W40 SYNTHETIC
058-198-025-A - GASKET SET
After they performed all this work the car ran fine until I was getting ready to go home from the gym and two of my coil packs failed and I had to get the car towed to the dealership late at night last Friday. I ended up replacing all 4 coil packs to be safe, at this point I'm cussing out all sorts of swear words.
Now, the oil pressure light STILL comes on intermittently. What is the deal? I am going to phone the dealership tomorrow and let them know what's up, but has anyone experienced this or know the cause of this dreaded oil pressure light? FYI - the weather here has been quite cold lately, about -5c to -10c.
