Results 1 to 40 of 106
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Re: Rough prototype A5/S5 style LED headlight done
    This is still my favorite:
    But, I want to extend the LED out more towards the center to make the straight across part a little longer. Which will work nicely once I add some more space between the two projector housings.
    It flows out of the hood seam better, and is easier to fabricate and overlay with CF. The design from tonight in the pics above where it goes all the way past the turn signal and curves up won't be easy because I'm using single LED's on the final version, not the flexible strip used in the prototype. As such, I need room behind it all for the LED wiring. That isn't a problem all along the bottom, or behind the "curve up" of my original design from page one. Over past the turn signal, however, that would mean I'd have to build out some plastic, or drill through the headlight lens to have the LED sticking out of the back of that portion of the headlight and in to the space behind the fender. Not fun.
    All youz haters can make your own damn design, lol. I'll come back to it this weekend and see if my thoughts are still the same. Sooner or later I'll stumble on the design that just "works".
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    [QUOTE=rxrep;3143549]This is still my favorite:
    That's the best one so far, I would like to see the LED's all the way towards the center grill.
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
