Results 1 to 7 of 7
    Established Member Two Rings S E B's Avatar
    Jul 12 2008
    2001.5 S4
    East Coast
    Transmission help (tip)
    Recently got into an accident, trans cooler had a hole in it. Half a quart of trans fluid most likely poured out. Got a new trans cooler assembled everything but did not add a quart of trans fluid yet. When i put it in drive I have to rev it to about 2-2,5k rpm for the car to move forward.
    No strange noises, no clanking, no CEL, everything seems like it should be working fine.
    (also the car hasn't been on for about 3months)
    What could be the problem? Could it be that there isn't enough transmission fluid?
    Veteran Member Three Rings Blue_S4's Avatar
    Feb 26 2008
    1968 plymouth roadrunner 440+6
    Rockford, MI
    Re: Transmission help (tip)
    add ATF...now, before you do any driving.
    B7 RS4...mmmm.
    Aug 06 2008
    Canadia
    yeah, if you gotta rev it like that, its going to be fucking up your clutches and stators pretty quick.
    sounds like there isn't enough fluid in the pan to maintain proper pressure, top it up before you even start the engine.
    the B5 S4 is like the mafia... there is only one way out!
    Jul 12 2008
    2001.5 S4
    East Coast
    I only tried it revving it about twice, wasn't planning on driving anywhere really just wanted to know if it drove so I don't think I messed up the transmission.
    Thank you for the replies, will do that right away.
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    lossen that filler plug (17mm) under the car, start the car and pump ATF into it till it starts pouring out. your done.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Aug 06 2008
    Canadia
    Quote Originally Posted by S4 in_lowplaces View Post
    after it starts pouring out, start the engine and keep filling with the engine running too, otherwise it will still be low. once it starts pouting out, re-install the 17mm plug, once thats done you can turn off the engine and lower it back down and drive again.
    also use fluid that is compatible with the audi fluid (basically any multi-vehicle ATF) its only compatible with itself, so they say, i'm not going to try and find out and i don't recommend you try either.
    Last edited by MacDaddy; 12-08-2008 at 09:27 PM. Reason: advice could have been taken the wrong way and made things worse
    Feb 09 2006
    Huntington Beach
    I got my ATF from Purems. ESCtuning also has it. just a matter of who's closer
