Results 1 to 40 of 43
    Sep 17 2006
    07 cbr600
    My AutoSpeed Gt28rs dyno
    Finally got this dyno from mark at ASP.
    let me know what you guys think. This was 21psi.
    Last edited by Russell2686; 12-09-2008 at 12:26 PM. Reason: made pic darker so lines easier to read
    Jan 25 2006
    A4 2.0T
    MD
    Re: My AutoSpeed Gt28rs dyno
    I guess it goes without saying that is a huge improvement over stock.
    Feb 27 2005
    North Wales, PA
    not bad. thats only about 300 chp. You should be able to squeeze another 20-30 whp out of that set up. cool guys at asp. i was at their shop on saturday.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Not to shabby. I was there on Saturday as well with Poopie, can't wait to see what 30psi does on their rollers on the 20th:) I agree with Poops you can squeeze another 20-30 out of it no doubt.
    Sep 17 2006
    07 cbr600
    yeah i def agree we could get some more out of it, Mark did say he kept it very conservative. I have to go back soon to get some stuff worked out and we may be doing the race gas tune.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by bassed View Post
    What he said.
    Those are decent numbers though, 4500rpm+ that's all "bye bye K04" territory.
    I'd be happy with those numbers. What fuel? W/M inj?
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    I expected more out of a GT28RS to be honest. Guess I'll have to lower my expectations for what I am going to put to the ground with my GT28 setup.
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by djwimbo View Post
    What he said.
    93 oct, no w/m
    2.5" APR exhaust and ASP HFC
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by GetBoosted84 View Post
    Yeah i was expecting a little more at first also but after i looked around it seems to be pretty decent on a mustang dyno. It is a ton of fun on the street though and has kept me satisfied so far.
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    What did you expect?
    This seems to be a very conservative tune as mentioned before. A gt28rs shouldn't have any problems with around 280awhp on pump, though that varies from dyno to dyno. I remember someone on here with 300awhp on their gt28rs set up.
    Apr 10 2007
    Eastern PA
    280 awhp is what I was expecting from a fairly conservative tune... hoping for 300 awhp but I would use the aid of methanol to attain that.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Russell2686 View Post
    NJ sucks doesn't it? I know the HFC isn't near as restrictive as the stocker, but I'll bet you would notice the spool and power difference without it.
    You should be able to run higher boost as well, octane dependent though.
    Sep 17 2006
    07 cbr600
    yeah the asp HFC is also 2.5" so i figure a 3" set up would definitely help but i don't think ill be changing it anytime soon.
    The stock runs were also with an atp 3" TP, the apr exhaust, and evo MS intake but the stock ecu, maf, inj etc.. Stock a4s are crazy slow
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    The lines on that graph is really dim, I can't make it out very well. Looks smooth though, and you doubled what you had so far.
    It's amazing what the difference between a modded but no software car puts down and one with software and equal mods. 30-60+whp gains on the K03/s.
    What's even more sad is that you 118whp ~ 151chp(figuring quattro loss), vs stock 150hp.
    Another $350-600 and you could have had software and a DV. Honestly though, I think you made the right choice.
    Sep 17 2006
    07 cbr600
    I had stage 1 software and a Baileys DV before this and they dynoed it at only 145whp or something like that at 17psi.
    Jan 25 2006
    A4 2.0T
    MD
    And thats all that matters.
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Very similar numbers to what I got on a Dynodynamics with my B6 71relim setup @~18psi.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I had stage 1 software .... and they dynoed it at only 145whp
    There's something wrong there. What software was that APR?
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    why? a chip brings you to a claimed ~200chp, which comes out to 156awhp with 22% DT loss. That seems about right.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Sep 17 2006
    07 cbr600
    this was their asp stage 1 software, comparable to the other big names
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Kyle H View Post
    I guess I wasn't thinking about claimed Stg1 software chp. I was going off my 1/4mi times and (flame suit ready) G-Tech readings.
    I guess I shouldn't expect much out of a K03, nobody else does.
    I'd like to think I'm in the neighborhood of 165-175whp. His mods weren't far off from where mine are now, maybe I should just find an AWD dyno around here.
    Oh well, you're past that now.
    Senior Member Two Rings S4stageIII's Avatar
    Dec 07 2006
    2013 Audi S6 stage 1 & 2001 Audi S4 AWE stage 3
    G-Burg, MD
    Nice numbers, did you do anything to the engine other than the 28rs kit?
    Nogaro S4..
    (AWE RSK04, Milltek DP, 710N, AWE intercooler, APR bi-pipe, APR snub, ASP DTS, Stasis Street, Neuspeed exhaust, ECS pulley, ECS stage 3 BBK, E-codes, RS4 bumper, AWE vented hood, etc...)
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by S4stageIII View Post
    Nope, the engine is 100% stock
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Just found this via-search... can the engine handle the ~280awhp of a gt28rs on stock rods? I always thought that with the quick spool it was pretty much a requirement to at least replace the rods.
    because racecar.
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    not at all...i think thats the point of getting a gt28
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    What about the gt2871? or is the gt30+ when you need to get rods?
    because racecar.
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    I have the gt2871r with the .86 exhaust housing. My motor is completely stock internals. I run up to 22 psi with no problems. Check out my build thread in the "projects" sub-forum. I have had the GT2871r on my car for 10,000 mi. so far.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    May 07 2007
    i think most with 2871 elim setups generally stick with stock internals...i think its the B6 guys that do rebuilds with 28 series turbos
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Ohh okay. I'm talking about the 'real' 28rs and 2871 if that makes a difference.
    this could be promising...
    because racecar.
    Feb 27 2005
    North Wales, PA
    i have a bent rod out of my old stock aeb. I was running 23-24 psi daily. Dynoed at 315whp. I recently discovered the rod was bent when I was cleaning up the garage and found them in a box. I was gonna clean them up and make a cool night stand or something out of it. Its bent just slightly. I don't think I could pick up the bend in a pic though. I would recommend scat rods if you are gonna go beyond 300whp. Sure, you could get away with out them, but seeing the bent rod makes me happy i threw in scat rods when I did the gt3071r upgrade on my old sedan.
    Dec 05 2007
    I read on Audiforum that you can run a GT2871r if you stay with the t25 flange. A T3 flange and you will need to do rods because of the faster spooling, as you already mentioned. But at that point, you are pushing the limit of the rods anyways at ~400chp so why not just get the T3 GT2871r and drive that thing for what it was purchased for in the first place. A GT28rs is fine on stock internals and moderate boost levels, unless you are the type to beat on your car as if it came from the planet Krypton. I think it is sean1.8t whom has a GT28rs and he said his car likes to take a beating. But he also said he does intensive logging.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by unorthodoxa4 View Post
    lol only because we want to make power, any Elim kit is at the edge of the stock motor on race gas, a 2871R is fine but don't crank the boost too high
    - Clint
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    I'm running a GT3071r with a T25 flange and I'm only pushing about 17psi....spools up fairly quickly....its definitely do-able to fun a BT/BAT on a stock bottom end, but a bigger turbo isn't REALLY that fun unless ur pushin 22+ psi.......hopefully I'll get there some day
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    stop reading things on audiforms.
    period.
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Sep 16 2006
    '98 528i
    Lol x2 ^^^
    Feb 27 2005
    North Wales, PA
    i completely forgot about that forum
    Sep 28 2006
    Lexington
    What's wrong with audiforums?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by AudiTurbo View Post
    streetracing, misinformation, and chips.
    because racecar.
    Sep 17 2006
    SLC, UT
    yeah, i prefer cheeto's over chips.
    and Audizine serves cheeto's!
    Current:
    Previous:
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    audiforums is generally the first forum people find when they google 'audi forums'
    then they discover audizine and leave AF.
    because racecar.
