Results 1 to 19 of 19
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Whistle at 2800 RPM
    So I have started to hear a slight whistle sound at exactly 2800-2900 rpm (no matter the gear) and only every so often. The whistle can be described as wind blowing over the top of a bottle or through a small hole. The sound is even present when I let off the accelerator and push no positive boost (still negative pressure showing on boost gauge).
    I wouldn't say it sounds like a dentist drill (Dad is a dentist I know what those sound like), but I can't for sure say it isn't the turbo. From the drivers position it sounds like it is coming from the front left wheel well and only makes the sound when moving. I know I am missing a couple of those plastic screw things in the wheel well leaving a small hole for air to travel through, but I would assume it would make a sound at any rpm as long as the car is moving.
    I hope it is not the turbo as I won't be doing my upgrade untill spring.
    58k on the clock. 1.8t q 6 speed. Boost tops out at 12 psi (stock) then drops so I would think the turbo wouldn't spike that high if it was having health issues....
    Any other infor that might be needed to diagnose let me know and i will see if I can get you an answer.
    Thanks for the help guys.
    Update:***
    I am not sure if whistle is the best word to describe it, I would call it a howling whistle. Not high pitched like a human whistling but not low pitch like blowing over a plastic coke bottle.
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Re: Whistle at 2800 RPM
    Is it whistling dixie?....JK you sure the sound is coming from the air flowing over the sideview mirror?
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Jun 10 2008
    Spiders
    Chicago And NJ
    Just drove back from work, and drove the whole way with the radio off. The sound doesn't happen in 1st, sometimes in second but just for a nano second, third and fourth are the most prominent, 5th and 6th I didn't use to much but I know it also does it in those gears.
    I was wrong in my original post, it starts at about 2600 and CAN GO to 2800. I say can because sometimes it doesn't.
    I didn't check if it made the sound with the window down, its freezing outside! I will be leaving for class soon so I will give it a try thanks!
    Jun 10 2008
    Spiders
    Chicago And NJ
    Not the mirror making the sound that is for sure.
    Jun 10 2008
    Spiders
    Chicago And NJ
    anyone...coke bottle howling!
    Dec 09 2008
    Wisconsin
    I'm getting a whistle now as well and I live just north of you in Il's largest state park (Wisconsin). I'm blaming the weather -it's been damn cooold.
    Also, I wouldn't describe the whistle as being over a coke bottle -it's higher pitched than that. It's almost the same tone as the door dinger, but more obviously air vacuum/pressure related.
    Spiff, who isn't that worried as it goes away after the first mile or so of driving
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    mine does; its been diagnosed as the turbo dying. start saving for a 1.9L and 3076 like me lol
    barrett
    2019 SQ5 Prestige
    Jun 10 2008
    Spiders
    Chicago And NJ
    I wouldn't say mine is high pitched, medium pitched.
    Apr 01 2007
    houston texas
    ^^^mine as well, and depending on how much throttle, meaning a little less that gets the whistling noise, it can even be a humming tone similar to a duck call lol but less "ducky" lol
    barrett
    2019 SQ5 Prestige
    Veteran Member Four Rings Undisputed's Avatar
    Jun 28 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Does it sound more like a tone than a whistle?
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Jun 10 2008
    Spiders
    Chicago And NJ
    Could be described as a tone (it is more tone than whistle)
    The best descriptive word is howl to me.
    Apr 01 2007
    houston texas
    that would be the one! I dont know why that sound occurs or what it means about the turbo other than it means its not "healthy"
    barrett
    2019 SQ5 Prestige
    Jun 10 2008
    Spiders
    Chicago And NJ
    Quote Originally Posted by texasboy21 View Post
    barrett
    But it does not have to happen under boost. I can be 20hkg and still get the sound, or I could be at 0 and still get the sound. It is also only in a set RPM range.
    I hope its not the turbo I still have 3 more months for saving!
    Jun 28 2008
    I'm thinking that it may be the fuel filter. I had a similiar tone that I was hearing and it went away when I changed the filter. If it were the turbo then you wouldn't hear it when you're just idling the car.
    The easiest way to check is to lay next to the car by the passenger side rear tire. The filter is located in front of that. If you touch it, then you'll feel it vibrating. That'd be the problem. 15-30min DIY and you're all good. Do a search in the B6 forums for fuel filter and you'll find alot of people that had the same symptoms. There is also a very good DIY writeup.
    Hope this helps.
    -Damon-
    Jun 10 2008
    Spiders
    Chicago And NJ
    Quote Originally Posted by Undisputed View Post
    Hope this helps.
    Thanks, I will check into it. I just had the dealer do the fuel pump back in August so it is a possibility.
    Mar 01 2007
    Bellevue, Wa
    It's probably the diverter valve honking, or if you have the apr R1 like i do it kinda makes a moo-ing sound while building boost or releasing pressure while on partial throttle, it's probably not the turbo pull the dv and check it.
    AZ Addict
    2003 1.8t Quattro 5 speed
    Mod List --= EuroGear Boser CF Hood, APR Stage 1+, APR R1, APR Snub, Magnaflow 16601 Exhaust, B5S4 Brake Upgrade w/SPP Dimpled & Slotted Rotors =--
    Jun 10 2008
    Spiders
    Chicago And NJ
    Quote Originally Posted by NeoAngelicRage View Post
    That is exactly what it was, i did the 710N in the summer, went back to my old one and the sound was gone. Had the dealer switch it out since I had the receipt.
    Still waiting for the snow to stop to put the new 710 back in.
    Thanks a million!
    Jun 10 2008
    Spiders
    Chicago And NJ
    Well it came back (not really positive it ever went away). I did find the following article and it describes my issue exactly. Only problem is this article is in Re: to an older model. THink it might the same solution????
    http://www.audiworld.com/tech/eng6.shtml
    Veteran Member Three Rings miggity02's Avatar
    Mar 22 2008
    '17 SQ5, MK7 GTI
    East Bay, NorCal
    Texasboy21...what is that diode mod you have? is it a DIY? I have the same car 2003 A4 1.8tq. Does it matter if I have Revo 1?
    P.S. sorry to thread jack, it just caught my eye.
    '17 SQ5-034 Stage 2 ecu/tcu-JHM 187mm CP-034 inlet, RSB, sub frame inserts-Eurocode trans/diff mounts-Alu Kreuz-B8/H&R-Neuspeed RSf72 20x9.5 et25-Magnaflow 11385-OEM airbox mod-aFe 11-10121
    Mk7 GTI-034 Stage 1 ecu/tcu-H&R springs/B8-Neuspeed rse11r
    Triumph Street Triple R-Full Arrow and tune
