I just purchased everything to do the brakes on my A4 except for new rotors and plan to tackle the installation this weekend along with suspension. The rotors I have are not that worn even though the car has 46k miles. I was under the impression that I could simply take some 1600 grit sand paper along with some stones to remove any built up crap on the rotors (no high spots). After reading though this thread is seems like I should be purchasing a new set of rotors. Any truth to this? I am installing hawk HPS pads along with Motul 600 brake fluid.
This is according to Tire Rack and makes some sense...
"IMPORTANT REMINDER: Slotted, drilled or dimpled rotors offered as OEM replacements should not be considered appropriate for high-speed track use.
While grooved, drilled and slotted rotors offer an enhanced appearance and add some resistance to the boundary layer of gasses that can build up between the pad and rotor, they are not designed to withstand the extreme temperatures that are produced on the racetrack. If they are used on the track, it is very important that the rotors be carefully inspected and should not be driven on if even minor signs of deterioration are seen. Note, too, that if these products are used on the track they are not warrantable."
I've done many brake jobs on my dirt bike and mountain bike (Hayes hydraulic), so the same principles apply.
Also how are the ECS and zimmermann rotors on ecs? The ECS rotors are either slotted or slotted/drilled and the zimmermanns look similar to the OEM's. If there is a significant performance increase I would consider going with the ECS slotted/drilled rotors. If they are merely for looks in this application, then I'll pass and go for the OEMs. Is there a reasonable chance I would experience damage with them on the track and will they make a significant reduction in brake fade?
