Results 1 to 7 of 7
    Senior Member Three Rings TverRus69's Avatar
    Sep 02 2008
    98.5 2.8 A4 QM
    NYC, Penn State, Tver Russia
    Stiff Shift into 1st when cold
    As its been getting colder i started noticing that its getting increasingly hard to shift into first. Is this fluid related? It gets normal again after it warms up after about 10 mins of city driving.
    Dec 05 2007
    Re: Stiff Shift into 1st when cold
    Normal. You will also notice that at times when shifting from 1st into 2nd that the gears will grind (as the weather gets colder). The gear oil needs to warm up a bit before you can have smoothe shifting. It gets better after the car warms up though. A good preparation can be to simply let the car warm up before driving off (~10min). A perk of winter.
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Some transmission fluid is better than others when it comes to cold weather, even fresh fluid would help depending on how long what you have in there now has been there. I believe I have redline mt-9 or something like that in my car now, and the shifts arent bad at all. This morning was about 15 degrees Fahrenheit and it was harder to get into gear but easy enough that I didn't even give it a second thought. The stock fluid that was in there before was much worse last winter.
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    yea same thing for me, not even when its cold, just when the oil isnt warmed up yet. Its sometimes hard to get it into 1st and/or is sloppy and also going into 2nd as well. On occasion i will only get it in half way going into 2nd and really need to pull that shit back to make sure its gunna stay in 2nd.
    But i have a lot of shifter play so that could have something to do with it.
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Normal, every car I've owned was like this.
    Veteran Member Three Rings fikes's Avatar
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    You want to really stop it. Get new trans fluid and a JHM shifter with linkage and it will be at least 50% easier when cold. Friend has both and that is my plans for the winter.
    1997 Audi A4 Sedan 1.8t- Sold
    1999.5 Audi A4 Avant 1.8t- Sold
    2001 Audi S4 Sedan- Current
    Dec 05 2007
    This was a topic talked about a while ago, and people switched transmission oils as recommended above. GM Synchromesh was the "New thing" when it came to the gears grinding. But there was a special blend (I can not recall) that our cars were able to accept. Do not use regular GM Synchromesh. But Redline is a def good choice for transmission oils. I think I may change mine to Amsoil in the near future.
