Results 1 to 8 of 8
    Veteran Member Three Rings Gallep's Avatar
    Mar 22 2004
    2014 Q7 3.0T, 2012 A6 3.0T
    Castle Rock, CO
    DS1 Bulb Part number for OEM replacement
    I tried searching with "D1S PART NUMBER" and "HID BULB PART NUMBER" with other variations in the B6 area but no results. Does anyone have it?
    Previous
    USP B6 A4
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: DS1 Bulb Part number for OEM replacement
    Um, wouldn't it just be a "DS1" bulb from Sylvania or whoever provides OEM bulbs?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Mar 22 2004
    Castle Rock, CO
    Quote Originally Posted by kwimberly View Post
    Right, it's actually Osram that supplies them. I know where to get them, I just need the VAG part number so I can look them up. Cause I can get them cheaper then ECS for example @ www.genuineaudiparts.com
    Previous
    USP B6 A4
    Dec 06 2007
    here is why u wont find ur answer:
    IT IS NOT "DS1" it is "D1S"
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings SoFresh's Avatar
    Mar 15 2006
    Seduction Motorsports 1955 Porsche 550 Spyder, Porsche 356 Coupe
    Scottsdale - Palm Springs
    Anyone know where I can order some aftermarket D1S bulbs?
    Production Manager - Gunther Werks
    Founder - Seduction Motorsports
    Dec 06 2007
    ^^ebay has them for cheap
    someone in the classifieds has a D1s full kit osram for $150
    -Kirk
    Mar 22 2004
    Castle Rock, CO
    Quote Originally Posted by AudiA4Turbo22 View Post
    My fault, I still can't find a valid VAG number under D1S...
    Previous
    USP B6 A4
    Dec 06 2007
    ^^they are made by Osram and philips check ebay u can get OEM ones from an A4 for under a hundred bucks.
    -Kirk
