You can do it yourself. get the torx bit that is recommended by audiS4man or what ever his username is.
Its real easy to do, you will see the two tabs right on top and the last is down the hole towards back of headlight inside each fender. My recommendation is put extension down and loosen the bolt all the way until its totally lose. Then take a magnet pen and fish it up out of the hole. its way easier. It also helps a lot when you want to fish it back down into the hole.
One more note is techincally it has 4 points of holding the headight to the car, 3 are screws, the 4th is a plastic hook that goes into a hole on the radiator support, or part of the car. Once you have the three bolts out you can wiggle the headlight out by sliding it sideways then out.
Piece of cake, you can do it. Dont waste your money with the dealership.
Once you do it you'll do the otherside in 15-20 minutes. well if you had to that is.
