Results 1 to 10 of 10
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    Those w/ a Podi boost gauge that beep's on shutdown
    Do what Winston wanted us to do in his original thread about the subject and tie to yellow wire (going to the battery) to the red wire (going to the ignition) so both red and yellow are going to the ignition.
    This will stop the beeping 100%!!! The only downside to this is that the needle on the gauge will stay were it was once the car is powered off, it will not sweep down to the bottom of the gauge like it usually does
    Thanks Winston!!
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    Re: Those w/ a Podi boost gauge that beep's on shutdown
    what is the point of this? Safety of the gauge? update?
    Oct 31 2007
    Grand Rapids, MI
    Quote Originally Posted by revhards4 View Post
    There is no point....if you recall, a few of us w/ Winston's B5 gauge started experiencing an annoying set of beeps emitted from the gauge every time the car was turned off. Winston sent me a replacement gauge, tested it himself before it sent out, and for some reason, the new one ended up beeping just like the old one.
    So, long story short, Winston talked to the manufacturers of the gauge and they told him to have use tie the two wires mentioned above together to cut power to the gauge immediately.
    Cheers
    MKIV BPM R32 (DD)
    Feb 14 2004
    Michigan
    oh, the beep is so faint I don't even notice it
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    I'm glad the fix worked and you can now enjoy the gauge instead of cursing as it.
    Oct 31 2007
    Grand Rapids, MI
    Quote Originally Posted by [email protected] View Post
    Ha, thanks a bunch again Winston, you have been great!!!
    And I didn't curse at it, after awhile, I found myself humming the beeping to myself as a way to try and calm myself down
    MKIV BPM R32 (DD)
    Oct 31 2007
    Grand Rapids, MI
    Really?? either way, podi gauge is deff the way to go!
    MKIV BPM R32 (DD)
    Feb 14 2004
    Michigan
    oh for sure, nicest setup I've seen and I gotta support the little guy
    Veteran Member Four Rings jursch2211's Avatar
    Feb 05 2008
    Illinois
    so then when you start the car again does the gauge do its full cycle test and then settle?
    || APR | BW K04-015 | ER FMIC | OEM S4/RS4/R8 Parts | '10 RNS-E | Hotchkis | Adam's Rotors | Podi | OCarbon | Euro Headlights | Euro Color DIS | Euro MKII TT MFSW | Euro Trunk | BBS | Vogtland Coilovers ||
    Oct 31 2007
    Grand Rapids, MI
    Quote Originally Posted by jursch2211 View Post
    Yes, it's just than when the car is shutoff, since power is cut immediately to the gauge, the needle will remain resting at whatever marking in the gauge.
    Once the car is started back up, it will proceed to do it's usual sweep motion, then rest at -20mmHg
    MKIV BPM R32 (DD)
