    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    Help: CEL- Low MAF or VAF reading
    EDIT: Thanks for the help guys!
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    Re: Help: CEL- Low MAF or VAF reading
    The clicking noises is from the check valve in the vacuum line for the n80 valve running to the evap canister, it is supposed to click.
    Unplugging the maf will make it run in open loop and run rich so you should be able to unplug it and drive with it unplugged until you get the harness repaired. I assume it is like a Toyota and the harness can be take apart to reinsert the wires but I have messed with an Audi connector yet.
    Jun 15 2008
    Long Island NY
    thanks, I appreciate the help
    Dec 20 2007
    iowa
    Sure.
    Registered Member Two Rings
    Jul 09 2008
    Napa, CA
    Did you connect the wire on the harness when the car was going? You could have short circuited the MAF. The same thing happened to me, as I was installing my Carbonio. I would have the harness looked at by someone who at least understands wiring, before you try to buy a new MAF and install. It may save you some $$$
