Results 1 to 32 of 32
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    B6 Blacked out grille & Audi Emblem
    I finally made the move this weekend and blacked the grille out.... and the audi emblem!
    She's a little dirty from the snow we had
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: B6 Blacked out grille & Audi Emblem
    I need to do that. I'll probably keep the rings silver though. What's on your headlights?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Oct 19 2008
    VA
    Eyebrows, not sure if im going to keep them on tho, what r ur thoughts
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    Personally I'm not a fan of the eyebrows but good work on the grille/emblem. What paint/how did you do it?
    Oct 19 2008
    VA
    Quote Originally Posted by Stone825 View Post
    I appreciate the input, there is a DIY i used from the forums HERE
    Basically bought 2 cans of plasti-dip spray paint (black obvi) and used a flat head screw drive to pop out hood grill. Lower grill pops out pretty easily, use the flat head once again with a rag around the tip. I coated 3-4 times
    PM me if you need assistance
    Deactivated Four Rings
    Sep 30 2008
    n/a
    take some real fine grit sandpaper now and sand the audi rings until they dont shine anymore and its gives it a nice brushed aluminum finish just like the rear strip on the trunk. had mine painted black stripped it back to chrome look now brushed aluminum. looks great imo
    Oct 19 2008
    VA
    Quote Originally Posted by NvrFllw View Post
    Really!? wow can I see a pic if you dont mind?! Im most certainly interested
    Sep 30 2008
    n/a
    yea ill try and get a picture later after work.. its freezing cold out and the car just went through a snowstorm ill stop at the carwash on the way home tho and post after
    Oct 19 2008
    VA
    hey no worries you dont need to do all that, just when time comes around and the symbol isnt covered in snow, and you remember. Thanks!
    Sep 30 2008
    n/a
    haha dont worry about it my uncle owns a carwash.. i wash it every other day im spoiled when it comes to clean cars
    Veteran Member Four Rings Rommulus's Avatar
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    You need to 100% lose those eye lids ASAP!
    Sep 30 2008
    n/a
    hey man i didnt forget about you i got out of work late last night.. ill post up pics during my lunch break
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Lose the eyelids and lower the car.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Oct 19 2008
    VA
    Yea See Thats What I Thought About The Eyelids As Well... Good Looks On The Help Everybody.. Lowering, Exhaust, And Chip Coming After Xmas As A Graduation Gift!
    Oct 19 2008
    VA
    Quote Originally Posted by nvrfllw View Post
    hey Man I Didnt Forget About You I Got Out Of Work Late Last Night.. Ill Post Up Pics During My Lunch Break
    Hahah No Worries Thats Straight
    Sep 30 2008
    n/a
    I hope this helps you. Use some back to black on the grille and it will look brand new
    Senior Member Three Rings B00sted20VUSP's Avatar
    Nov 11 2008
    Junk
    Chicago, IL
    Those brushed rings look SICK!
    /S4 25 Quattro #139 | JHM 93 Oct Tune | Fast Intentions Non-Res Exhaust | Trexturk Downpipes | VMR Staggered Gunmetal 710's | RS4 Grille | RS4 Pedals
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    Please explain in more detail how to do the rings!!
    They look so sick!
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    +1 on ditching the eyebrows.
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Take the Quattro off
    Established Member Two Rings truman's Avatar
    Jun 17 2008
    2004 Audi A4 1.8t
    Everyone, enough. This post was originally to show you his grill/emblem mods. Not his lights. He obviously put the eye brows on there because they looked good to him. So leave it alone!
    Sep 30 2008
    n/a
    Quote Originally Posted by NightRoller USP View Post
    They look so sick!
    Take really fine grit sandpaper and sand the rings until the chrome (shine) is gone. It will look very dull. Just be careful not to sand to much cause you can go through to the crap plastic underneath.
    Active Member Two Rings gdubz77's Avatar
    May 25 2009
    2004 Audi A4 1.8T
    Minnesota
    is there any tricks to sanding in the tight spots on the audi rings?
    Veteran Member Three Rings android3000's Avatar
    May 28 2009
    '04 1.8t USP 6mt
    Knoxville, TN
    ^^Like the look of the brushed aluminum rings... I went with silver but I might go back to that
    -Andrew
    Frankenturbo/GIAC
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    I'm digging this ^^ Looks clean
    Did you just sand them and call it a day? Or was there anything else to it?
    How about getting the rings off, did you do that?
    Veteran Member Three Rings HamidsVikes's Avatar
    Jan 10 2008
    Vancouver, BC
    gotta loose the eyebrows bro....
    and the amber must go as well...
    but if you like the eyebrows keep them, but not my cup of coffee!
    Active Member Four Rings schmally's Avatar
    May 19 2009
    Nothing worth adding
    Alabama
    this was an old thread..
    Gcc's blacksheep
    Jun 21 2008
    Quote Originally Posted by schmally View Post
    I know, but those brushed rings look siiiiick!!!
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    anyone ever painted the rings the color of their car, besides black and red. Like, any dolphin greys do it?
    Senior Member Three Rings dpc1192's Avatar
    Nov 11 2009
    B6 1.8T
    Southeast
    so all you need is some back to black cleaner for the grille itself?
    I was looking into getting a grille, but if all I need is a cleaner and this DIY I'm down as a clown...
    my grille itself is pretty old looking/faded, so if this cleaner really can make it look like ^^^ im stoked
    Senior Member Four Rings spector's Avatar
    Sep 08 2009
    SE
    Dude, that is EPIC. That is exactly what I want the front of my car to look like.
    After sanding the rings, what else did you do to them?
    Veteran Member Four Rings Lusticles's Avatar
    Nov 04 2009
    a lemon
    i think if the car was lowered it'd look a lot better. (even though this thread is really old)
