Results 1 to 3 of 3
    Veteran Member Three Rings mwbunns4's Avatar
    Feb 20 2008
    2011 Audi S4 6MT, Audi A3 TDI
    Savannah, GA
    lug bolt size for Volks
    anyone know what size and length lug bolt i need to run my 18x7.5 volk TE-37 et35? i am pretty sure they need to be conical and 14x1.5mm, but im not sure what length they need to be. anyone have volks and know what the length is? also where i can get the lug bolts?
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Re: lug bolt size for Volks
    Most Volks we've seen are 30mm length conical.
    You can test fit using a stock bolt to see if you're close. Just count how many turns you get until the stock lug is snug. If you get close to 5 turns, then a 30mm bolt will work fine.
    We've got all the lug bolts you need.
    Feb 20 2008
    Savannah, GA
    the stock lugs head is too big to fit. I belied the stock lugs are ball seat and I need conical. any idea where I can get the lugs?
