It's a rubber accordion looking circular protective boot and is full of drive axle grease that keeps the Constant Velocity joint lubed (drive axle joint). The rubber axle boot is exposed to the elements and spins with the wheels. Over time the boot gets brittle and deteriorates, especially in our hot and try climate. When this happens it throws all the grease out and makes a big mess on the inside of the wheel and undercarriage leaving the joint with no lube. If the boot is not replaced in a timely manner it could be costly and may need the drive axle replaced. This boot replacement on an Audi here at Vivid Racing is $240.00 installed at dealers $400.00 installed. So when you hear the term "Torn open CV Boot" think Vivid Racing.
Jeff Vivid Racing Shop
480-966-3040 x239
[email protected]
