Results 1 to 34 of 34
Thread: E85
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    E85
    Ok, so I was in York, PA Sunday morning getting gas @ a Toms and saw they had E85 there for $1.59. I decided to put 5 gallons in and then I filled the other rest of the tank up with 93 (8 gal). The S ran great the whole way home (70 miles) and I swear I felt a little more pull. I know if a ran a whole tank of it I would have fuel issues, and as far as I know I have stock injectors. Anyone else used this besides those of you that have the ECU tuned accordingly??
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    Re: E85
    i know that e85 gas conducts electricity and ive heard a must to run it is a fuel pump that does not conduce i.e. a walbro...idk about audi's but i guess most stock pumps are not fully sealed electrically. but im interested in where this goes because i would like to run e85 exclusively for cost effectiveness
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: E85
    Quote Originally Posted by sdoherty_tjm View Post
    I don't think you want to run e85 exclusively..
    08 S4- Stock SOLD
    Oct 20 2008
    fuck off
    Re: E85
    why wouldnt i?
    Registered Member Two Rings
    Oct 15 2007
    Audis & BMWs
    SoCal, Taiwan, HK & Penang
    Re: E85
    Try fill the whole tank of E85 and keep us updated with a write-up maybe :P
    01.5 S4 TIP (Stage 3-)
    K04s, RS4 mount, 710Ns, Open DPs, Defi HUD, 18" BBS RCs, FK Coilovers, Milltek Cat-Back, AMS/ABT Chip, 22% titanium tint, lip spoiler, E-codes.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: E85
    why wouldnt i?
    E85 is like 105 octane. By "exclusively", I take it you want to fill your entire tank with e85 all the time??
    08 S4- Stock SOLD
    Apr 25 2008
    Baltimore
    Re: E85
    Yeah, I heard that it needs a different fuel pump as well, but I thought that was just for pumping out fuel faster.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    Oct 20 2008
    fuck off
    Re: E85
    well i know e 85 requires twice as much fuel or some shit, thats why suburbans and shit get better mpgs on reg gas cus the compression isnt enough for the better power.
    but yes i would run e 85 all the time. its 20% of the price of 104 in chitown at least.
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: E85
    Quote Originally Posted by nateS4 View Post
    Yeah you would need a larger fuel pump, injectors and a MAF
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: E85
    You're probably going to want to do some more research. Most people mix it. I'm no expert but running straight e85 all the time on a non tuned car can't be a good idea.
    08 S4- Stock SOLD
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    Re: E85
    You would need Larger Injectors, and a Fuel pump like Bosch 044. You can run it with a Stock MAF if you are on K03. To run 100% E85 you will need to be tuned for it, car wont go far without a tune and pure E85
    Established Member Two Rings jaredsogn's Avatar
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Re: E85
    Maybe it is cost effective if you compare it to race gas, but that would need an E85 specific tune. I live in South Dakota, so we have E85 as well as E30 everywhere. E85 is not cost effective if you compare it to normal gas. It is about 10 or 20 cents cheaper, so less than 10% cheaper, but it gets roughly 30% less MPG. So it actually costs more to run than gasoline. I have had good success with E30 however. You could mix it to make E30 with E85 and gas, but we have mixer pumps here that do it for you to make E30. I run E30 and did some preliminary tweaks adding about 10% primary fueling and it pulls harder. FWIW, E30 is roughly ~95 octane. I am going to be doing some more logging and tweaking to see what I can get out of it.
    Stay away from Audspeed! Scammer! Read more here.
    Apr 25 2008
    Baltimore
    Re: E85
    Quote Originally Posted by 2001S4NY View Post
    I am running GIAC 93, would 50/50 mix be ok with e85 and 93? I just don't want to loose any performance.... only hope to gain a little, but without larger injectors at the least its probably all in my head that car pulls a little harder.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Re: E85
    SSP can set you up to run 100% E85. I am thinking about doing it if he can make it have 2 maps on one ecu.
    Oct 20 2008
    fuck off
    Re: E85
    of course with a tune and maybe nin south dakota pricing works that way but not here. when 93 was $4.85 e 85 was 2.80-90ish. i drive over 20k a year and within next summer with a tune im pretty sure id break even. im not saying with out a tune though, thats why i said i'd LIKE to. reg gas is e10 here btw
    Oct 20 2008
    fuck off
    Re: E85
    Quote Originally Posted by Evilevo View Post
    id love to have a quick switcher too. from 93 to e-85. you cant get e-85 everywhere lol
    May 26 2008
    MD
    Re: E85
    Just to let you know, You will NOT get better gas mileage with E85. Even on K03s you will need 60# injectors as E85 requires ~30% more fuel. Even tho E85 is cheaper you will end up using more of it.
    Apr 25 2008
    Baltimore
    Re: E85
    I would definitely like that, more HP at the price of Reg gas minus the the whole gas millage part. Still cheaper that buying 104 race gas...
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    May 26 2008
    MD
    Re: E85
    That is why people run it! You are buying racegas at the price of pump. Not to get better gas mileage.
    Oct 20 2008
    fuck off
    Re: E85
    yes exactly. thats why i want it. im not paying the 7$ for 104 or 110 around here
    May 26 2008
    MD
    Re: E85
    Get in contact with SSP. Greg can set you up with an E85 tune
    This is Greg
    Oct 20 2008
    fuck off
    Re: E85
    have you gotten a price before?
    May 26 2008
    MD
    Re: E85
    I am already tuned by Greg. PM him for a price 2001S4NY
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: E85
    Wow, didn't realize it needed that much more fuel. So it seems like it's a cheap alternative to race gas for recreational or track use, if you don't give a hot butter about fuel economy. But as for it being used as a daily driver, anyone have consumption numbers? I mean, e10 pump gas is almost down to under 2 dollars here in MD for 93 premium.
    08 S4- Stock SOLD
    May 26 2008
    MD
    Re: E85
    Quote Originally Posted by mholme View Post
    I seem to remember TommyGunn said he only got like 15MPG or so with E85.
    At this point, with 93 being almost below $2.00 here in MD i dont see the need to switch to E85 unless i wanted to run racegas.
    Edit: Here is Tommy's post from another thread
    Quote Originally Posted by TommyGunn View Post
    I've been running E85 for the past 3 months. You cant run E85 in a car tuned for 93. The A/F ratio is completely different. As for 10-15% I'm not so sure about that one..... I currently adv 13 mpg vs the 18-19 I used to get on 93. ::This is a city highway mix:: Also city driving or traffic will DESTROY your fuel economy, however with that being said you will not save any money what so ever by switching over to e85. The only gains E85 has over 93 are;
    1. E85 is equal to 100~110 depending on what time of the year.
    2. You do not need Catalytic converters for E85.
    3. E85 is currently $1.57 a gallon. ::12/3/08 in Longisland NY::
    4. E85 is rejected and hated by Saudi Arabia
    5. Filling up for under 20 bucks and having an extra 100 ponies under the hood is AWESOME!
    On a personal note, I Gained 100 HP according to ARP explorer. I also cut my F.A.T.S. times by almost a second. When I ran 11.6 I logged my car and my fats times were 3.6 seconds with an ambient temp of 85* Later that same week I switched to E85 and Logged my car and got 3.08 fats with an ambient temp of 85*.
    If you have any questions please contact me or 2001NYS4 for all your E85 needs.
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Re: E85
    Yes, I realize that. Pricing works the same here. Maybe it was cost effective this summer, but not now is what I'm saying. Because the price of E85 is only 10-20 cents less right now, it is not cost effective. When it was almost 2 dollars less, then it was. For you to break even, the price of E85 has to be more than 30% cheaper than regular gas. Also, regular is E10 here as well...
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: E85
    I'd think you could probably get away with 89 octane with that high of a mix? I don't know, like I said before, I'm no expert on e85.
    It might not be in your head about the car pulling harder. I swear mine pulls harder on certain gas(Shell, Sunoco). But then again, maybe that's all in MY head
    08 S4- Stock SOLD
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    Re: E85
    so E85 is slowly coming to the EAST coast? I can't not wait.
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Re: E85
    All this talk is good news. Added power plus better for the environment. But i would be careful if you dont have a tune. Im going to investigate these E85 stations, bc personally ive never seen one and I live on LI where Tommy and 2001S4NY gas up.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Re: E85
    i think E85 should get its own sticky now since its becoming almost a question asked regularly
    Apr 25 2008
    Baltimore
    Re: E85
    Quote Originally Posted by infinkc View Post
    I think that's a great idea. I just learned about it last week from a thread, as far as availibilty, tune, injectors, fuel pump etc. If you go to the national website for E85 you can do a pump locator by zip code, and then like I originally said there are some in York, PA. One off 116 and the other off of 124 I believe. Both were Toms gas stations that had bio diesel as well. I like being green, and getting a little more power, even if I'm only breaking even on cost.
    http://www.e85fuel.com/index.php is the web site
    Here are a couple local stations:
    Maryland/DC Area
    Fredericktown Chevron
    1395 W Patrick Street
    Frederick, MD 21702
    301-694-6277
    Quik-Mart Citgo Parole
    2042 West St.
    Annapolis, MD 21401
    410-571-9676
    Montgomery County Agencies-Fleet Mgmt Services
    16640 Crabbs Branch Way
    Gaithersburg, MD 20855
    240-777-5730
    Germantown W Express
    20510 Frederick Road
    Germantown, MD 20876
    301-353-8288
    Town Center Chevron
    12301 Middlebrook Road
    Germantown, MD 20874
    301-972-5122
    Congressional Plaza Sunoco
    1469 Rockville Pike
    Rockville, MD 20852
    301-770-7240
    Tacoma Park Texaco
    6400 New Hampshire Avenue
    Tacoma Park, MD 20912
    301-270-7119
    Pennsylvania
    Tom's (I'm pretty sure I was there)
    2905 E Prospect Rd.
    York, PA 17402
    717-757-4290
    Tom's (Other one of 116 close to York)
    502 North Main Street, Suite 2
    Spring Grove, PA 17362
    717-225-4298
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    Long Island, NY
    Re: E85
    you can also go to www.e85refueling.com
    there are 2 e85 stations now on LI one is in massapeque and another on rt109 near farmingdale
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Re: E85
    you mean 3.
    l gotta-- l gotta get
    a form from a scientist.
    Veteran Member Three Rings Spooled1.8's Avatar
    Jan 26 2006
    York, PA
    Re: E85
    I think I know the Tom's your talking about, it's right by my place. I was already thinking about having SSP tune my car when I go stage 3, might just have to get an E85 tune since its so readily available here.
    -Pete
    2001 Imola Yellow S4 EPL/TiAL S605
    -Evolution Racewerks Intercoolers with Carbon fiber shrouds.-EBC Redstuff Pads-EBC Rotors-RAI Motorsport 3" Downpipes-AWE Twin 1 Exhaust-AWE DV1 DV's-AWE Center Vent Boost Guage-AWE DTS Bar-Advanced Automotion Rebuilt Trans-Southbend Stage 4 Clutch-Fidanza LWFW-ASP Engine Mounts-034 Motorsport Trans Mounts-Apikol Rear Diff Mount-KW Variant 3 Coilovers-
