FIRST: Use a monkey wrench to lift up or clockwise on the belt tensioner (yellow circle). Its easier to reach if you remove your intake inlet there (the 2 scews). So while lifting on the tensioner, simultaneously pull off the belt from the alternator pulley. Once you get the belt off, be careful not getting it off track of the lower pulleys, and make sure to take a visual note of how it runs through there.
*note...this next picture is with the alternator and intake manifold hose already removed and fan blade pushed forward.
SECOND: Move on to the second picture. Follow the green arrow. Remove the two clamps that hold on your intake manifold hose. Pull that bad boy off so you have more hand room in there.
THIRD: Is the tricky step. You have to stick something fairly skinny through that groove on the fan assembly and through the fan pulley (blue arrow). Theres a hole in the pulley you cant see so place something in that groove, push it towards the radiator, and keep rotating that pulley until it slides through. I used a t-handle allen wrench. Then there's the allen hole in the back there (red arrow). Not quite sure what size this is but I want to say it's around 8mm. I had to use an allen head socket. Just remove that bolt and then push the fan towards the radiator. Should pop off with a little effort.
FOURTH: Back to the first pic. Now you can access and remove the bolts that hold the alternator on. This is the part that was hardest for me because i had no idea if they were allens or torx bits and what size they were. This next part is described with what I used, ive heard they are allens but i tried them and they werent working so i used torx bits. The top one is a Torx 40 bit (orange circle), and the bottom is a Torx 50 bit (pink circle). May have to use a little pb blaster to break these loose, just be careful to not spray it on anything electrical. Remove those bolts and you're now able to access the plug and power wire on the back of the alternator. MAKE SURE YOUR BATTERY IS DISCONNECTED HERE BECAUSE IT IS A LIVE WIRE YOU'RE ABOUT TO TOUCH! Both are easy and straight forward so no worries there. Now pull that thing out of there! It's easier to remove if you take out that little plastic cover on the power steering resevoir. Hope this helps and like always, i am not responsible if you break or strip anything or mess anything up
