Results 1 to 10 of 10
    Established Member Two Rings A4nEeDsMoRe's Avatar
    Jul 12 2008
    Atlanta
    purchasing rims...
    So I am looking into getting some new footwork: VMR RS4 Reps in Onyx Black (19x8.5). I am far from a car wiz so I was wondering which offset to go with: 38 or 48? Also, I want my rear tires to appear a little wider so what spacers do you recommend? Like I said, don't know too much so would appreciate all the help...
    Thanks,
    Austin
    20% Tint. H&R Springs. 19" VMR Reps. APR 91/93/100. Magnaflow Exhaust. OEM Bi-Xenons. RS4 Grill.
    Rep if I help.
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    Re: purchasing rims...
    well if you want your wheels to sit more flush with your fenders, go for the lower offset. the higher the offset the farther in they will sit. as for spacers it depends on how far out you want to go... ET 38 with 5 mm front and 10 mm back would probably look pretty good
    two thousand two audi a-four quattro five speed
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    with some variance... 19x8.5 wheels with 245/35 rubber will be nearly perfect at ET+35. That being said, get the +38 offset, 3 mm spacers in the front (+35 is SO flush in the front with 8.5/245) and I can't give u a def answer on the rear, since it is pretty flush, but I've always thought I could bring out the rears a couple (2-3) mm [from +35] so for you it would be 3 mm to get to +35, so I would try 5mm to +33 or even 6 (if possible) to +32 since i heard that is good, but never tried myself with spacers.
    Jan 22 2006
    2006 B7 A4 s-line quartz grey
    socal
    How would 19x8.5 ET35 with 245/35 all around look?
    I'm still waiting on my wheels and i'm curious how they would look.
    Do you recommend a 2~3 mm spacer on the rear to look balanced with the front?
    Jan 06 2008
    Dacia Sandero
    Arizona
    ^^ That'll look flush. Thats the perfect offset.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Jan 22 2006
    socal
    Meaning, with the spacers or not?
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    He means without spacers. ET35 will sit flush with the fenders. If you want the rears to sit a little further out (which some people like) get a small spacer.
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Jan 06 2008
    Dacia Sandero
    Arizona
    ^ What he said.
    Nov 12 2007
    Grand Junction, CO
    The problem with those small spacers is that you really have to be careful when put them on the car, and put the wheel on the hub. It has to be centered perfectly or you will get vibrations.
    Oct 27 2008
    Studio City, California
    get the matte black..
