Results 1 to 6 of 6
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Early Christmas Gift - 1870cc (1.9L) Displacement Increase kit
    Ok guys,ordered these for a customer but he changed his mind and wanted to go with a stroker set up (2.1L) so I have these still in the box.No wait time,just order and go
    SPECS:
    * Bore = 83mm
    * Wirst pin size = 20mm
    * Compression height = 32.8mm (for 86.4mm 1.8T stroke)
    * Compression Ratio = 9.5:1
    * Coated skirts & Crowns (200US value)
    * Rings & Wrist pin included
    The retail on these are 901.11 US + shipping.
    PRICE = $750US shipped or 1050US SHIPPED with a set of SCAT 144/20mm rods.
    Send me a PM
    Thanks
    Jan 25 2006
    A4 2.0T
    MD
    Re: Early Christmas Gift - 1870cc (1.9L) Displacement Increase kit
    Is that a JE coat or an aftermarket coat like a Swain tech dome coat?
    Looks nice, I wanted that on my pistons, but never happened.
    Feb 26 2006
    Earth
    Thats a coating supplied by JE pistons.
    Coated skirts & Crowns.
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Dumb question, but does this kit included everything needed to make your engine 1.9L? If so, how much does labor on a job like that usually go for? Stupid I know, but I'm just curious.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Feb 26 2006
    Earth
    Quote Originally Posted by Exanimas View Post
    The only component needed to go 1.9L is the oversized pistons going from an 81mm bore to an 83mm bore.
    You will need to remove your block and have it bored out to match the piston specs.I recommend changing the bearings and seals when the motor is apart.
    Feb 26 2006
    Earth
    Bump it up!
