Results 1 to 23 of 23
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Early Christmas Gift - 1870cc (1.9L) Displacement Increase kit
    Ok guys,ordered these for a customer but he changed his mind and wanted to go with a stroker set up (2.1L) so I have these still in the box.No wait time,just order and go
    SPECS:
    * Bore = 83mm
    * Wirst pin size = 20mm
    * Compression height = 32.8mm (for 86.4mm 1.8T stroke)
    * Compression Ratio = 9.5:1
    * Coated skirts & Crowns (200US value)
    * Rings & Wrist pin included
    The retail on these are 901.11 US + shipping.
    PRICE = $750US shipped or 1050US SHIPPED with a set of SCAT 144/20mm rods.
    Send me a PM
    Thanks
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Re: Early Christmas Gift - 1870cc (1.9L) Displacement Increase kit
    GL with the sale issam, i`m pretty sure someone will take em.
    and that customer wasnt me!!!!
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Oct 06 2004
    Minnesota
    NASCAR!
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Apr 22 2007
    Riverbank, Ca
    We can go to 2.1??
    Feb 26 2006
    Earth
    Quote Originally Posted by andyrew View Post
    We can go to 2.1??
    With a 95.5mm crank yes
    Sep 14 2006
    Lansing, MI
    ^^^^interesting!!!!
    SOLD
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Quote Originally Posted by Issam@034 View Post
    TDI crank, correct?
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Feb 26 2006
    Earth
    Quote Originally Posted by JumboBlack1.8 View Post
    TDI crank, correct?
    Yes
    Sep 16 2006
    '98 528i
    There isn't a lot of info out there about the TDI crank......would an 06a block require any additional machining to account for any clearance issues of the 95.5mm crank?
    Sorry for the thread jack
    Feb 26 2006
    Earth
    Not the 06A block.A 058 block yes...for sure.
    The 06A block has alot of room in the crankcase for crankshafts larger than 86.4mm
    Apr 22 2007
    Riverbank, Ca
    How would making the engine more of a stroker affect high end RPM's? For instance if you built it to rev to 8.5k all day long?
    Feb 26 2006
    Earth
    Once the rod ratio is within the acceptable range (which all crankshafts available are) then you will rev to 8500 rpm's no issues.
    Oct 29 2005
    10speed
    San Francisco, CA
    bump for a good dude
    - Clint
    Jan 25 2006
    A4 2.0T
    MD
    Bump for a nice piston.
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    I can get a TDI crank tomorrow for like $50(cheap right...? ), still need to check it out to make sure there isn't any major scoring. What else do i need to look out for, and what all is needed for the use of it in my 058, 06A build...?
    He's got the block and some other bits and pieces, anything i should offer money for...?
    Oh, almost forgot, if you still have those items in 3 weeks, a friend of mine who will be in the USA can pick them up for me.
    Sep 16 2006
    '98 528i
    From what I've read, I believe you'll need to look for a pre-'98 TDI crankshaft, since the newer ones are a bit longer. I could be wrong....but I read that somewhere last night....I"m still researching so i'm not 100% sure
    Oct 19 2008
    South Africa
    See! I knew there was a reason i liked you guys so much.
    Waiting for Issam to advise.
    Feb 26 2006
    Earth
    Quote Originally Posted by kovalevandrew View Post
    Get me the engine code of the TDI crank and I will go from there
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    issam is the fuckin man
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Apr 22 2007
    Riverbank, Ca
    How much HP (or should I say Tq) can the TDI crank hold?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    well past 300hp and 500wtq(from a running diesel). At least that's what I've seen in person. I'm sure they can hold more than that as they are forged. I don't know any body (in person) that's currently using that crank, so I don't know.
    Bump for a good price.
    Free for me right? 'Cuz I'm a pal?
    Feb 26 2006
    Earth
    Quote Originally Posted by djwimbo View Post
    Sure!
    pay the shipping
    roughly $1000US or so....hand delivered
    TDI cranks will take 900hp no issues.
    Feb 26 2006
    Earth
    Bump for pm's
