Results 1 to 18 of 18
    Nov 29 2008
    '05 S4
    Salt Lake City
    Cold start problem fixed
    Like many others out there, I also had the cold starting problem where it would take anywhere from 30 seconds to 5 minutes to start when it was cold out. Replaced the starter and problem solved. Wasn't too hard to change. Just had to pull the sway bar and one of the motor mounts and that was all that was needed to get to the starter.
    Re: Cold start problem fixed
    Quote Originally Posted by red0hero View Post
    Glad you got it resolved, now get out there and have some fun
    Established Member Two Rings bigredx24x's Avatar
    Sep 23 2008
    06 25quattro s4, 95 Ford Rgr, 05 sv650
    DC
    Same thing happened to mine, glad you were able to fix it. I take it your car was not under warranty?
    Nov 29 2008
    '05 S4
    Salt Lake City
    Sadly it's not under warranty. 75,000 miles on it.
    Dec 05 2006
    So. Cal.
    Good work and good post.
    Veteran Member Three Rings AndreNY's Avatar
    Apr 06 2005
    Boston MA
    sounds good, my starter just came in today and will be installing it tonight, so hopefully my (cold start) problem will also be cured
    Senior Member Two Rings TN2004S4's Avatar
    Jun 18 2008
    B6S4, 07ODYSSEY(KIDS)
    Fairfax, VA
    Quote Originally Posted by bigredx24x View Post
    same Thing Happened To Mine, Glad You Were Able To Fix It. I Take It Your Car Was Not Under Warranty?
    I Have Post This Same Question On My Thread Before, But Did Not Get A Clear Answer. I Own A Cpo Audi. It Has 74k On It Now And The Warranty Does Not Expire Until It Hits 100k. Will They Cover The Starter Under The Cpo Warranty?????
    Sep 23 2008
    DC
    Quote Originally Posted by TN2004S4 View Post
    I don't know for sure, but why don't you just call and ask them? I got mine replaced under the standard 50k/4yr warranty. Good luck.
    Apr 06 2005
    Boston MA
    well did the starter last night and this morning was about 30 degrees, car fired right up, i guess that solved my problem as well about the "no start when cold"
    Jun 18 2008
    Fairfax, VA
    Just Called And It Is Cover Under The Cpo Warranty.
    Nov 29 2008
    '05 S4
    Salt Lake City
    Quote Originally Posted by AndreNY View Post
    Glad you got it taken care of.
    Veteran Member Four Rings Silver B6 S4's Avatar
    Dec 08 2008
    2003 PT Cruiser GT Stage 2
    Petaluma, California
    I am having the same problem... I ordered the starter Monday and haven't recieved it yet.
    This morning it was 32 degrees outside, and I tried to start the car and nothing happened... I used the spare key I have and it fired right up. What would cause this??? Bad batteries in the key fob?
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Quote Originally Posted by Silver B6 S4 View Post
    Just co-inci-dink unless you can achieve this repeatedly. Mine was the starter too.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Dec 08 2008
    Quote Originally Posted by S4J View Post
    It's weird, Monday morning I waited 10 minutes before it would start. Tuesday and Wednesday, I used the spare Key and started up right away.
    This morning, I went out with both, used the one that's hard to start, and nothing. Put the other key in, and it started right up.
    I will take a video tomarrow morning to see if it does it again...
    Alex
    Established Member Two Rings Shonobi's Avatar
    Feb 24 2006
    2004 S4
    Dirty Jersey
    Thats interesting about the keys...I hear BMW has an issue very similar and was corrected by using the spare keys. The chip in the original key was the problem. Any, I had the same "Cold Start" issue, so I tookmy car to the deal and they found that my battery was not "holding the charge." So, they replaced it (September), 2 months later....same issue, now its colder.....they replaced the battery again (underwarranty). I am thinking I should replace the starter the next time or try the spare keys.
    Shonobi
    Dec 08 2008
    ^^^ I just replaced the battery on Saturday thinking it would solve the problem. The stock one was almost 6 years old, and didn't have a green eye.
    Sep 23 2008
    DC
    Good news. Congrats.
    Nov 29 2008
    '05 S4
    Salt Lake City
    Quote Originally Posted by Shonobi View Post
    Shonobi
    When my cold start problem was beginning, I tried using my spare key and it would start, but it would still take about thirty seconds to start up (not nearly as long as my regular key). But since I replaced the starter, it starts right up every time.
