Results 1 to 13 of 13
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    K04 stud installation
    How do you tighten down the exhaust stud on a new set of K04's? I can't get two nuts on there to do in the old fashion way.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Senior Member Two Rings nocturnals4's Avatar
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    Re: K04 stud installation
    I used red lock tight and used pliers to grab the part of the stud that doesnt have threads. Havent gotten the car running yet so dont know if they will hold but thats what i did.
    Jul 06 2007
    San Jose, CA
    Never mind. My friend who was doing it is retarded.
    Dec 10 2007
    '00 S4, '94 Z28
    P-dena,Maryland
    I had one of those helping me to lol
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    I didnt use any thread lock on my. I used two bolts that thread on the stud turned each in a different direction to get them tight and tighten the stud.
    Remember the short side of the thread goes in the turbo.
    Veteran Member Three Rings RusS4's Avatar
    Nov 14 2006
    2000 Audi S4,1980 VW Caddy,05 R1
    VA
    Holy old thread Batman! Na but I was wondering what the torque specs were on the exhaust manifold studs and the nuts for the studs
    Tial 605's EPL Tuned
    Lots of other goodies.
    Veteran Member Three Rings Matt Danger's Avatar
    Jun 04 2007
    B5 S4
    ROC NY
    Quote Originally Posted by RusS4 View Post
    Tighten the studs down as well as you can with pliers and then torque the nuts to 18 ft/lbs
    770r B5S4 home built & tuned
    Nov 14 2006
    VA
    Really!? Aight thanks man, I jus didnt know if there was a specific torque.
    Jun 04 2007
    B5 S4
    ROC NY
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    any reason studs are used? When I pulled my dp's off, the bolt stayed on the stud and the stud got pulled out. I replaced the studs with regular bolts and lock washers.
    ThorTechnik.com
    Aug 19 2013
    minnesota
    what are the torque specs for the turbo to cat studs? i got 2 nuts on them but dont know how far to go?
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by jacobsen View Post
    25 nm = 18 ft-lbs
    Sep 11 2009
    NE
    25 nm = 18 ft-lbs
    I think he is asking about actual stud into flange, not nut to stud.
    There is no torque specs for stud itself, you just screw one in until it stops, which normally it does once you run out of thread. Torque exerted by the nut (once you fasten the other part on top of it) is what holds it in place on both ends.
