Results 1 to 14 of 14
    Veteran Member Three Rings Bryan's Avatar
    Mar 20 2007
    Vancouver
    Question where can I get quad tips for my STaSIS exhaust ??
    I want to add quad tips to my STaSIS exhaust, so I need to cut original single tip then just welding on new tips right ?? any website that I can get quad tips ??
    thank you guys !
    Bryan K
    06 B7 A4 - Slightly Moded.
    09 8P A3 - Slightly Moded.
    10 B8 A5 - Slightly Moded.
    11 B8 S4 - Milltek exhaust, H&R, BFI spacers.
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    Re: where can I get quad tips for my STaSIS exhaust ??
    Quote Originally Posted by Bryan View Post
    thank you guys !
    Check out Magnaflow tips.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    I think vibrant also makes some nice tips. another member on here was supposed to undertake that project but i havent heard anything about it. post pics asap when you do it !
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Mar 20 2007
    Vancouver
    ^^ I went Magnaflow web, then I found this one:
    http://www.magnaflow.com/02product/s...e=main&id=8087
    but I am not sure it will fit the S4 rear valance or not ? any help !
    Thanks =P
    Bryan K
    Mar 20 2007
    Vancouver
    and it's like $120 for each side....damn expensive / __ \
    Bryan K
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Quote Originally Posted by RedS-line View Post
    Vibrant does make nice tips.
    I did what you want to do with my Milltek, but with oval tips. Basically the same mod.
    Is a pita to get them just right, but its worth it.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Mar 20 2007
    Vancouver
    Nice lookin!! BTW what the size is ur tip ?? any recommed for dual tips ?
    and how much u cost just welding on ??
    Thanks, have a nice day !!
    Bryan K
    Oct 14 2006
    MK6 Jetta
    South,FL
    They are:
    Inlet Diameter: 2.25"
    Outlet Size: 5.5" x 3" Oval
    Overall Length: 7.5"
    Welding cost was about 100$ since I had to redo one of the tips.
    Lets say you like this ones:
    http://cgi.ebay.com/ebaymotors/Exhau...QQcmdZViewItem
    They measure:
    Outlet Diameter: Dual 3.5"
    Overall Length: 10"
    A common misconception is that you just slap them on. For them to have that oem look, you must cut the back of the tips, bend the exhaust and hangers, and have them welded very carefully.
    Dont get discouraged, it sounds more complex than it really is.
    -EI AL CAI.
    -Driver Mod.
    Nov 05 2007
    Oregon
    the caveat with adding quad or the vibrant ovals (which is what I did) is that the exhaust cut out of the 2.0 single tip is further out toward the side of the car than the S4 cutout, so you have to angle the last part of the pipes toward the middle of the car to fit the tips through the required S4 valence, bringing the hot pipes closer to the heat shield around the underside of the spare tire well (not especially advisable), and this gives them a look that they're angled toward the middle of the car, not straight out. As the gentleman above experienced, my muffler guy spent a long time trying to make this work, fabricated new sections of pipe, but 2 appointments into it (and he's good!) it still is angled a bit. If you're looking for total perfection, keep that in mind. It still looks pretty good however. I'm going back to him at some point and seeing what else he might be able to do.
    Would love to hear if anyone else has found a better solution, besides a $1000+ loud replacement for the exhaust, which, yes, I would like (but the wife wouldn't).
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Bryan, there was a guy with an 08 Ibis on here a while ago who posted picks of quad-tips that he welded on to his stock mufflers. I can't remember the brand but they looked perfect! I did a quick search but couldn't find the thread. I think the guy was in FL and had a red B6 A4 that he gave to his daughter. Maybe someone here remembers and can pull the thread.
    Black B7 Titanium - Sold
    APR93 | Carbonio | Vogtlands | RS4 sway | Abt quad-tip | Podi | BBS RCs w/RT-615s | RS6s w/W300s
    Nov 12 2007
    Grand Junction, CO
    I'm working on that now. Should have something soon for you guys.
    Mar 19 2008
    Louis, I would like to see that thread if you could find it cause i cant. are you sure youre not thinking of the guy with the white a4 with the custom magnaflow mufflers?
    2019 S5 BO.SS
    2009 R8 6 Volt :)
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by AudiWxGuy View Post
    Can you elaborate more? thanks
    Mar 20 2007
    Vancouver
    Thanks u guys !! ~~
    Bryan K
