However, it needs a new timing belt, water pump etc. which i've done my research on parts but im concerned about the labour. I've read that most of the people on the forum are comfortable doing it themselves and said there are plenty of DIY tutorials on how to do it. I personally have only found B6 tutorials. maybe a link would be greatly appreciated.
Secondly, I am in the process of putting the car through the safety process, my mechanic has informed me that i need to fix front upper control arm (bushings), ball joints. on the passenger side. would i be better off to buy bushings separately or to purchase a whole new control arm with the bushings already installed?
Finally, my rear left tire/wheel makes a humming sound as i drive. I suspect it to be the wheel bearing because i can hear it more when i turn and increase/decrease speeds? Does this make sense?
What i am most concerned about is the decrease in speed almost like light pressure on the brakes when i release the gas pedal. Now the weird part is that when i put the car in neutral and release the gas there is a less drastic decrease in speed. a normal feeling.
Is this typical for the quattro system? to have poor road resistance? if not what else could i be having problems with?
Note: My abs module needs to be rebuilt (abs light is on and ebrake light flashes) and the rear pads and rotors to be replaced.
Any of help in regards to these topics is greatly appreciated in advance! I am extremely impressed with my first audi.. it's dope..haha
THANKS!
Nick
