Alright, so as you guys may know, I've needed a clutch for a long time ...
Yes, I have searched and have read all the threads i could find, however i have a few questions still.
I just happened uppon a AWE LWFW for 150$ and am planing on purchasing it.
I am planning on replacing the friction surface, but cannot find them for sale anywhere. Does anyone know where they can be found and how much they go for?
Is it worth buying used and replacing the surface, or should i just buy new?
As far as the clutch goes, I am debating whether to go SB stage 4 or 5, and if i go 5, what options.
How many miles can i expect on the stg4 vs 5? It will be mostly dd, with some track days and autox.
I live in Colorado, an make a lot of trips to the mountains for snowboarding. Often times, the trips back are stop and go in the mountains, so i am kinda worried about the 12lb flywheel with stage 5. Is this not a good flywheel to go with?
Also, should i get stock or upgraded flywheel bolts and will the clutch kit come with pressure plate bolts?
I guess i should include my mod list to help you help me:
K04
Evo MS intake
custom greddy intercooler
Forge 007
Revolver Cams
Lightweight crank pulley
Custom 3" exhaust
PCV/SAI Delete
GIAC Chip with custom tuning, 93 and race gas (not just a file)
Neill
