Results 1 to 8 of 8
    Senior Member Three Rings blackbox619's Avatar
    Oct 24 2008
    nyc
    VAG-COM my rns-e?
    hi, can anybody do this for me please? my rns-e doesn't track my current position, instead it jumps every 3 minutes to locations that i've been to. i bought a rns-e plus and need it coded for my b7 please. im in brooklyn,ny if anybody has access to it. i will compensate for your time. thank you :D
    ~~ engineered in germany... modified in brooklyn ~~
    Re: VAG-COM my rns-e?
    Quote Originally Posted by blackbox619 View Post
    I have a VAG in Northern NJ if you want to drive a little.
    From the sound of your post though it seems you arent getting very many satellites. Do you have the antenna under the dash or you running to the sharkfin?
    Oct 24 2008
    nyc
    hi joey, thanks for replying. im getting about 4 satellites i believe and the antenna is placed behind the speedometer. i thought that it was gonna be an easy plug and play install. i also lost the steering wheel control functions, the unit shuts off after exactly 30 minutes, the buttons under the monitor does not light up either. the only time it did track me was when i drove for over 3 miles... i was so excited to see it actually follow the route that i was on. later that evening, i got back into my car and the nightmare started all over again.
    hmm... very weird... What version of SW is the unit currently running? Doesnt sound like its the antenna anymore if your having issues with the unit as well.
    Senior Member Two Rings AudiA4b6US's Avatar
    May 10 2005
    Chicago, IL
    Sounds to me as if the speed signal is not received by the RNS-E or the tire size (channel 1) or pulse (channel 2) are set incorrectly.
    Senior Member Three Rings Kerby's Avatar
    Nov 10 2008
    I park on the street.
    Brooklyn, NY
    I know i'm late but i have the blue vag cable if you still need it, I'm in flatbush or by hofstra university in uniondale, LI.
    Soon
    HPF M3
    Gone
    G37S
    B7 A4
    E39 M5
    SC300 TT
    Oct 24 2008
    nyc
    thanks for the reply but i sold my rns-e a lil over 2 months ago. thanks again!
    Mar 10 2009
    clifton nj
    need help with drls in north jersey
