Car was running fine until i sprung a boost leak. TBB was torn and i replaced with a samco. Tightened and checked all of the clamps. Now all of a sudden the car is shuddering under a load/wot at peak boost and i got a flashing then solid check engine light. Hooked it up to vag and read multiple misfires 1 or 2 here and there and misfires cylinder 3, 25-30. Change the coilpack. Same shit. Check the forum, search, read, change the plugs. Same shit. Next suggestion??? Cylinder 3 location driver side closest to radiator correct?
