Results 1 to 11 of 11
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    painting + winter question, pic for fun
    basically my car was in a n accident 2 months ago, still at the audi shop.. taking their sweet as time.. basically my suspension was messed up.. my wheel caved it.. bending all sorts of sexy objects.. according to them.. they had to take my dash out to replace my steering column or someshit.. which was bent into the firewall... suspension.. control arms..tie rods..etc etc.. my fender and two doors as well..and i got s4 door blades added for free, jus cus i can.. NOW once uve read all that useless info... they're about to paint everything.. door blades, fender and doors.. does winter have an effect on new paint?.. does it cure fast?.. im in canada, its a harsh winter.. i know not to wash the car right away bla bla.. but snow/ice settles on the car..
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    Re: painting + winter question, pic for fun
    id try to keep it out of the snow and ice if you can, although a car cover with snow on top of it might be just as bad, when mine got painted they said not to even wax it for 6 months, id think a fabric cover with the weight of the snow would have about the same effect as rubbing it with wax?
    Please Drive Right
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    any decent paint shop will be doing the painting in a temp controlled environment and then 'baking' the paint to cure it. 90% of full cure is done at this point, but temp will effect the full cure point. the "don't buff it for a month" rule is to keep from hurting paint during this final step and it is a pretty generous length of time for most areas, temps etc. winter in canada will lengthen that time, but should still be fine for driving etc. if you have a garage, i'd park it in there, maybe you have a car cover? try to be as gentle on it as possible with driving through snow and ice.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Mar 20 2008
    Ottawa, Ontario
    thanks, so they bake it to cure it.. that's kinda good news.. i do not have a garage nor a cover, it's my DD.. i been runing on rentals for 2months, it's at an audi body shop... they must know their ish.. thanks again.
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    Damn dude, I have 20% tint and I thought that was really dark. what percentage is yours?
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    haha, your "walk" symbols in canada are funny looking
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Jun 02 2008
    Quote Originally Posted by jon102034050 View Post
    HAHAHAHAHA!! that little guy on the light looks so proud and happy
    Please Drive Right
    Mar 20 2008
    Ottawa, Ontario
    u guys are juuust jealous :P... its' 5% all around, cops aren't as anal as u.s troopers
    Veteran Member Four Rings BlackB6's Avatar
    Apr 03 2008
    Pennsylvania
    Tint always looks darker on black cars, especially with black interior such as my car. 15% and you can barely see in day or night.
    Mar 20 2008
    Ottawa, Ontario
    another question.. how do make sure all my quattro and differial components are runing smoothly.. dyno it???
    OEM is sexy.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    They should be checking all the mechanical and electrical components before it leaves the shop you could ask to have them pull the codes to ensure everything is clear and ok before you drive away and get a cel or have issues.
