Results 1 to 21 of 21
    Jan 11 2007
    Salt Lake City, Utah
    I finally got my vag-com cable to work!
    Just thought I share cause I'm stoked that something actually worked for once!
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: I finally got my vag-com cable to work!
    What did you do to get it to work?
    What problem were you having? This could be helpful info for others who are having problems getting their vag-com to work.
    Usually the problem is getting the com port set right to run with the program.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Vista or XP?
    B5 S4 AWE Stage 3 - sold
    Established Member Two Rings s4Xcelence13's Avatar
    Nov 15 2008
    Stg II+
    Dirtee Jerzee
    Ya seriously.. im using XP and in only communicates with my ECU once in a blue moon.. and not even an OBD-II scanner can read my ECU..
    /_/// GIAC-Xr /_/// SSAC DP /_/// AWE-TWIN 1 CB /_/// FORGE MB /_/// FORGE 007 /_/// RS4 CLUTCH & FW /_/// AWE BOOST GAUGE /_/// 18' RS4 RIMS /_/// STAGE 1 STOPTECH BRAKES /_/// SSP Transmission Rebuild /_/// JHM FMIC /_/// JHM SS /_///
    "I have a love-hate relationship with my S4. I feel safer on a racetrack than I do on New Jersey's freeways."
    Nov 23 2007
    Columbus, OH
    hmm, i've never had a problem with XP and vag-com. Strange
    Nov 15 2008
    Stg II+
    Dirtee Jerzee
    It used to work when i first got the GIAC-Xr but after while, it just stopped communicating, and even the OBD-II scanners, i cant even go to inspection!!!
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Quote Originally Posted by s4Xcelence13 View Post
    Your problem sounds more of a ecu problem or possible dirty connection instead of your vag-com software.
    best way to try is with someone elses odb II cable (sounds like you tried this already) or using someone elses laptop with the vag-com software.
    from my own experience and trying to help others I've found a few things with getting vag-com to work:
    1. With xp it will work fine, biggest problem is setting the com port. Sometimes they will be used and you have to go into control panel and free up one of the com ports 1-4. this has to be done with the cable hooked up to car after the driver is installed for the usb odb II cable.
    2. with vista you have to run the program as administrator (right click on the vag-com icon, then chose run as administrator)
    again you have to set the com port, this has to be done with the cable hooked up to car after the driver is installed for the usb odb II cable.
    If you are running vista 64 bit, I dont think it will run vag-com at least I havnt seen it work. If someone has gotten it to work, let us know.
    Nov 15 2008
    Stg II+
    Dirtee Jerzee
    If its a dirty connection, any way to clean it... cause my VAG works on my friends A4 and like i said used to work... and now my OBD II scanner doesnt even work... Says No link
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I'm thinking you might have to replace the connector. I dont even know if that is possible. I would say it has to be, but havn't looked down there to see what the odb II connector is hooked up to under the dash.
    Jan 11 2007
    Well I bought a key-com and bought the wrong serial to usb adaptor, though it was the keyspan brand. I tried everything with that adapter. I was going to sell the vag and do the ebay cable, but I decided to man up and buy the usa-19hs serial to usb adapter from Keyspan since I already have the real ross-tech cable. I had already read so much on it that setting the com port on the cable was easy and I was just surprised how it just simply worked when I plugged it in and ran vag-com!
    BTW, windows XP
    LOOKING FOR:
    Nov 15 2008
    Stg II+
    Dirtee Jerzee
    what i dont understand is how it always used to work and now it just stopped... does it just hate me or what lol
    Aug 06 2008
    Canadia
    I have no luck with my laptop, its a HP and aparenty the way it emulates serial ports is weird, i tried the run as admin since i'm on vista, gave the cable its own port, all that stuff, it recognized the cable now, and it didn't do that before, but when i plug it in i get no signal.
    other vag com cables have worked with my car, so its gotta be the computer or the cable.
    I just got an oldschool laptop, its running windows 2000, going to see if i can get that to work with the car.
    the B5 S4 is like the mafia... there is only one way out!
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Trav u have a check Engine right??
    Aug 19 2008
    Longmont, CO
    I have been running Vag-Com with Vista 64 for about a year now.
    Nov 15 2008
    Stg II+
    Dirtee Jerzee
    CEL and probably a few other goodies.. cmon you where there lol
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    LOL...i forgot.....it's def ure ECU bro....go get that fixed
    Veteran Member Four Rings 1sadavant's Avatar
    Jun 21 2005
    '01.5 S4 & '05.5 M3
    Murrysville, PA
    Bump, need an answer from the guru's: I am running Vista OS, with the Keyspan USA-19HS usb adapter mated to the Vag-Com ISO cable. I followed the advice of running the program Ross-Tech 311 software as an administrator, but the following issues have come up:
    Specifying a Com Port:
    1) Com1: Inaccessible
    2) Com2: Inaccessible
    3) Com3: Com Port Status: OK Interface 5 Status: Modem!
    4) Com4: Com Port Status: OK Interface Status 3: Not found or not ready!
    So, How can I set this up properly? FWIW: I am running a Lenovo X61.
    2001.5 Audi S4 6spd ASP Stg 3 Imola
    IG: dr.yellowbird
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Ill can get it sometimes to work on vista but it always freezes right when I open the program. Ill have to try the run as administrator next time.
    Veteran Member Four Rings TWiST's Avatar
    Jun 08 2007
    I use VagCom on Windows 7 with a Ebay blue FTDI based cable without issue
    Jun 21 2005
    '01.5 S4 & '05.5 M3
    Murrysville, PA
    The main issue is that I am running an iso-com vag com the first cable made by rosstech in 2000 with the updated 311 software for iso.
    IG: dr.yellowbird
    Dec 08 2009
    Muncy, PA
    Quote Originally Posted by system_s4 View Post
    Are you running a version newer than 409? I think he may be talking about running versions 311 and 409 on 64-bit windows. I have the same problem with versions 311 and 409.
