Results 1 to 11 of 11
Thread: Problems!!!!!!
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Problems!!!!!!
    Well I did a pull on the highway, and all of a sudden lost power, EPC and traction light came on, and the car wouldnt accelerate. Pulled over and sounded like it was missfiring, put it in 1st gear and move but couldnt and almost stalled. Iam pretty sure its coilpacks, but just want to get some suggestions on other things it could be? Had to get the car towed home..... $114 dallors later, here Iam.
    Thanks
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    Re: Problems!!!!!!
    have a VAG-COM scan it see if you got any misfire code.
    P0300
    P0301
    P0302
    etc..
    May 21 2007
    Florida
    Re: Problems!!!!!!
    epc makes me think speed sensor. but ide vag it first.
    2018 Navarro Blue Q5
    Nov 04 2007
    Minnesota
    Re: Problems!!!!!!
    I have to find someone local that can do it, cant drive the car anywhere
    Current:
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    Re: Problems!!!!!!
    when its idling unplug a coil pack, if there is no difference in the way the engine is running, that CP is bad, go through and check them all one at a time, new ones are usually only $30ish bucks even from the dealer
    good luck
    Please Drive Right
    Nov 04 2007
    Minnesota
    Re: Problems!!!!!!
    is it fine to let the car idle with bad coilpacks, it wont be bad for he engine
    Current:
    Jun 08 2008
    Calgary AB Canada
    Re: Problems!!!!!!
    just aslong as you dont do it for too long youll be okay.
    Nov 04 2007
    Minnesota
    Re: Problems!!!!!!
    sounds great, so you guys think its also coilpacks, ive checked to see if i blew any intercooler hoses off, and that fine
    Current:
    Jan 24 2007
    Re: Problems!!!!!!
    Have you recently did any work to your vehicle?? EPC light usually mean Vehicle speed sensor is either bad or is misadjusted
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    Re: Problems!!!!!!
    same problem for me... except when i restarted the car everything was fine...
    has happened to me a bunch of times, but only when cruise control is on...
    it's a mystery
    two thousand two audi a-four quattro five speed
    Nov 04 2007
    Minnesota
    Re: Problems!!!!!!
    Quote Originally Posted by A4_Joe View Post
    no recent work
    Current:
