Results 1 to 22 of 22
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    whining from power steering
    So recently I saw that my reserve for Power Steering was getting low (not extremely low, but it read "LOW" on the dip stick.. Ever since I notice my car makes this whining noise when I turn the wheels under 15mph! I know I have bald tires, but that shouldn't really be the problem...
    ALSO where can i buy Power Steering fluid.. Since this car doesn't take normal everyday P/S fluid... it takes hydraulic mineral oil. Where can I buy that!? Kragen and Autozone only sell Hydraulic fluid for like jacks and stuff.. Is this a stealership part!?!?
    - 2016 VW MK7 GTI Performance Pkg. DSG/Nav/Light pkg/cloth seats.
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Re: whining from power steering
    search
    High speed Ferrari movement...
    Feb 27 2008
    Quote Originally Posted by Boosted3.0 View Post
    search
    gave up after like 2 min of looking b/c the darn thing kept telling me to "wait XX seconds before continuing" so I figured it wouldnt hurt to ask, and it wouldnt both a nice AZer to quickly explain to me the issue
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    check for PS leak.
    your PS fluid shouldn't be in low.
    Jan 24 2007
    yeah you should check for leak & if you don't find the leak add p/s fluid
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    Mine did the exact same thing. It wasn't even that low. Had to buy some from ECS (nothing local) and it dosen't whine (or leak). Any VW/Audi dealer should have it or just order off line.
    Veteran Member Three Rings Hamotee's Avatar
    Oct 30 2005
    Other German Stuff
    Athens,Ga. Clemson,Sc
    Dealer is your best bet. It was around $17 for a 1L bottle though. Some people have recently reported using non Audi P/S fluid without any problems. Like everyone else said, try to find the leak. Pray that it is not from the rack (Its very expensive).
    How to account for this massive success? Pure luck? Transcendental meditation? Machiavellian manipulation? Aerodynamics? High colonics? We haven't the slightest idea. -P.L. Newman
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Quote Originally Posted by Hamotee View Post
    damn i wish it was liek 28 after my discount at my audi dealer.
    you can also use this , im not sure if autozone carries it
    Oct 30 2005
    Other German Stuff
    Quote Originally Posted by vdubstreets View Post
    $28?? That is insane. Was it made of baby seal tears and unicorn horns?
    Established Member Two Rings afozzie40's Avatar
    Oct 21 2008
    B6 A4 1.8T
    Boulder, Colorado
    I have been topped off by my dealer for free before. my dealer is the shiz
    03 B6 MT Sport suspension 15% Tint Custom Magnaflow exhaust K&N Stock Air Box Mod ECS Snub
    Feb 27 2008
    well its strange because it as at "normal" on the dip stick and when I took it to my dealer to have the front bushings replaced.. Also they did a tire alignment. Since then when I checked the fluid level it reads "LOW" and it whines when you turn the wheel under 15mph or so. If I put it on the ramps today, what area should I look around for leaks..(ex where is the steering rack)
    THANKS
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    NAPA carries this if you have one in your area, I did not see it at Advance Auto Parts or Autozone. It was 22 dollars for me.
    Oct 30 2005
    Other German Stuff
    This is for B5, but it will give you an idea of where the rack is.
    Jan 24 2007
    Because p/s is at MIN mark that doesn't always mean it's always leaking. It could be either bad PDI or when you get the car service nobody check of the condition of the p/s level.
    P/S level change if the vehicle is cold or at operating temp. When the vehicle is warm up it should be 3mm higher.
    If you guys are having P/S noise concern follow this step
    1. Check the level of P/S when the vehicle been sitting for about 2 hrs or more.
    2. If the level is at MIN or below check for leak
    3. If no leak is found, Add p/s fluid to MAX. level
    4. Drive the vehicle to warm up the car & the P/S fluid
    5. After test drive let the vehicle sit for about 1-2 minute then open the p/s reservior *If you see a bubble forming when you crack open the reservior, the noise was cause by AIR due to P/S level being to low*
    6. At this point let the vehicle sit for another 2 hrs so fluid could cool down & settle. Check the level again & top it off to MAX.
    This should help little bit with p/s noise concern & remember on a cold day little noise is normal.
    Veteran Member Four Rings Dylan's Avatar
    Mar 28 2008
    i just had this problem too - just got some prestone p/s fluid (<$10), topped it up, problem solved.
    it's not the hydraulic mineral oil stuff, but still solved the problem.
    BRING BACK GCC REP!!
    jason1st: If you just want a good job and to be able to take care of your family with a lot of security etc. Canada is a great place for that.
    If you want to crush your enemies, see them driven before you, and hear the lamentations of their women, then the United States is where you should be.
    (_|_) 4
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    I just had that problem. I was leaking PS fluid and kept having to re-fill it. Aparently I needed a new motor mount.
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
    Veteran Member Four Rings jriddle11's Avatar
    Mar 26 2007
    B7 3.2Q and C7 A6
    Byers Audi - OH
    Mine started making that noise about 2 months ago (under warranty) went to the dealership and they topped it off for free for me. Then last week the noise back (again they topped me off for free) and now they need to find the leak. My car has been at the dealership for two days and they cant find the leak. My car is now out of warranty but since the car was brought in while under warrenty they think they can get it fixed under warranty, but they need to find the leak. Could it not be leaking and just using up more fluid? Any assistance would be great.
    Audi Brand Specialist / Social Media Manager / Spokesperson Byers Imports (Audi, VW, Porsche, Subaru)
    Current: B7 OEM+ and C7 OEM
    Previous: B5, B6, B6 USP All OEM+
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Quote Originally Posted by jriddle11 View Post
    Tell them to take the clamps off the tie rod boots and look in them. That's where fluid collects if a seal fails near the inner tie rod. If you have an alignment done and they use a lot of heat on the rods to get them un-siezed it can eff the seals. Why would I know this? Because it happened to me and I had to replace the rack... $$$ The worst part is that there is really no way to prove that they messed it up. In my case it "curiously" started leaking badly out of both sides immediately after the alignment. Coincidence?
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Apr 20 2007
    Lander, Wyoming
    Quote Originally Posted by bmags88 View Post
    How is your motor mount affecting your PS fluid level?
    Jon
    go > show
    Ich liebe mein Audi
    Mar 26 2007
    B7 3.2Q and C7 A6
    Byers Audi - OH
    Quote Originally Posted by lookaught View Post
    Thanks, I had them do that and nothing. The first time I brought the car in the the fluid was really low, so the conclusion they came to is that I had air in the fluid and that caused the noise to come back.
    by the way I was born in Pittsburgh and am originally from Oakmont and would like to say GO STEELERS!
    Mar 27 2005
    The Cold North
    Quote Originally Posted by Dylan View Post
    you might want to get the ps flushed and refilled with the proper ps fluid. otherwise good luck.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Senior Member Three Rings Boston_USP_327's Avatar
    Nov 24 2008
    2004 A4 USP 1.8T 6MTQ
    Grafton, MA
    i had the same issue... had the dealer look at it during a oil change... needed a new rack. big $$$. luckily i am still under warranty and it was done free of charge, but it would have cost me close to $1800 parts labor and alignment... that is from a cheap dealership who only chafges me $52 for a oil change... good luck, hope its something minor
