Results 1 to 17 of 17
Thread: BBK Q's
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    BBK Q's
    Ok so i just put on some stoptechs on my car. My questions are:
    1) What do I do about the brake warning i'm now getting?
    2) I had to use 3mm spacers to get them to fit under stock wheels but now my steering wheel is shaking. How can I fix this?
    So far i'm very pleased with them just have those 2 questions.
    The usual things!!
    Resistor Install
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    Re: BBK Q's
    1. If the replacement pads did not come with wear sensors, you need to create something that will close that loop and fool the computer to think the pads are wired.
    2. Make sure that you have properly seated spacers, the thinner the spacer the harder it is to make sure things are seated. Just stick with the star tightening pattern and you should be fine.
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Feb 16 2008
    Oakdale, MN
    Re: BBK Q's
    1) what can I get/use to do this? I know the B5 S4 owners have done it but i don't know what to do.
    2) I'll take the wheels off again and see if I can get them to sit better.
    The usual things!!
    Resistor Install
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B9Q5
    Honolulu, HI
    Re: BBK Q's
    I've never done this before but I think you can cut the old wiring harness off the OE brake pads and splice the ends together and plug it in.
    Current:
    2024|A5 SB PP+ S-line, 2019|Q5
    Previous:
    2017|S3, 2016|A4 2.0T Quattro, 2006|A4 Avant 2.0T Quattro S-line, 2005|A4 3.0 Quattro UltraSport
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    Re: BBK Q's
    From the stock pads, cut the sensor thing off and solder the two wires together, then plug that into the connection. That *should* work
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    Feb 16 2008
    Oakdale, MN
    Re: BBK Q's
    hahaha ok i'll give that a try.
    The usual things!!
    Resistor Install
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    Re: BBK Q's
    Can you not simply turn the pad wear indicator off with Vag-com in the instrument cluster?
    Feb 16 2008
    Oakdale, MN
    Re: BBK Q's
    Quote Originally Posted by Keith@APR View Post
    I don't know. You are APR, can you do it? have you done it to your cars?
    The usual things!!
    Resistor Install
    Senior Member Three Rings B7 Projectile's Avatar
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Re: BBK Q's
    Are the spacers hub-centric?
    2007 Ibis Audi A4 2.0TFSI Ti Package
    Vorsteiner CF Hood.APR K04.APR HPFP.AWE Exhaust.AWE FMIC.034 HFC.KW-V2 CO's.Forge DV.3000k HID Fogs.Smoked Tails.Custom Intake.Heatshield.CC Mod.35%Tint.Blacked Rings.RS4 Rear Sway Bar.Podi boost gauge.
    Ah...so many pedestrians, so little time...
    Jul 11 2005
    Auburn
    Re: BBK Q's
    Quote Originally Posted by cstarky15 View Post
    I've done it on countless mk4 and mk5 chassis VW's, B6 S4's, TT's and A3's. I've never had the occasion to try the B7 A4. However, we have 2 here with BBK's and no pad wear indicator lights. I was just wondering if anyone had tried it on a B7 A4 and it didn't work. I assumed this knowledge was well known. I will find out tomorrow!
    Feb 16 2008
    Oakdale, MN
    Re: BBK Q's
    Quote Originally Posted by B7 Projectile View Post
    No, As far as I know nobody makes a 3mm spacer that is hub centric. Or they are but they don't have the lip for the wheel to remain hub centric.
    If you figure it out will you let me know how to do it? I can get access to a vag-com so that isn't a problem. That would solve me from cutting up my stock pads to try and solder them together.
    The usual things!!
    Resistor Install
    Nov 12 2007
    Grand Junction, CO
    Re: BBK Q's
    seems like a big pain in the ass? Hopefully you get this figured out cause they will look bad ass.
    Feb 16 2008
    Oakdale, MN
    Re: BBK Q's
    Yeah it is a little annoying. Here is a picture of them after some fun in the snow
    The usual things!!
    Resistor Install
    Veteran Member Three Rings Tru NY Player's Avatar
    Apr 27 2007
    TIME MACHINE
    Tha M.I.A.
    Thumbs up Re: BBK Q's
    a little cold eh?
    they look nice though..
    'Leave sooner, drive slower, live longer.'
    Registered Member Two Rings
    Nov 02 2008
    08 A4 2.T S-line Titanium
    Eden Prairie, MN
    Re: BBK Q's
    Nice cstarky! Buy them new?
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    Re: BBK Q's
    This is a little off-topic, but how is the paint on the wheels holding up to the snow?
    2015 Audi S4 Prem+ Sepang Blue/Magma, 6MT, Eurocode Alu Kreuz, Eurocode Transmission Brace, Eurocode Sway Bars and Endlinks, RocEuro Intake, AWE Touring Exhaust
    Feb 16 2008
    Oakdale, MN
    Re: BBK Q's
    Quote Originally Posted by Tru NY Player View Post
    a little cold eh?
    Cold? not with heated seats. Can't complain about the snow. It gives me something to do.
    Quote Originally Posted by saimasta View Post
    I got them used from BigBen on the other forum. He just reaplaced the rotors and hats and the pads have half life left. Sorry about the other night, I was really tired. It is going to snow the rest of the week I hear so I'll give you a call.
    Quote Originally Posted by EMAXX View Post
    So far so good. They have a few chips that are no bigger than your pinky nail. I know i got some marks from getting my alignment done so the paint seems to be doing fine. I'm sure I'll touch it up in the spring just to make them look prudy again.
    The usual things!!
    Resistor Install
