Results 1 to 13 of 13
    Jul 04 2007
    Anchorage, AK / Chicago, IL
    Small feature I never knew...
    If you have your AC on full blast in manual mode with the temp on HI, when you pull for wiper fluid the AC will run at a higher fan speed for about 10 seconds. Nice to get a little extra heat in the car when its really cold.
    Veteran Member Three Rings Clown4's Avatar
    Aug 29 2008
    '08 Quartz Gray S-Line B7 2.0T
    Rainbows and Unicorns
    Re: Small feature I never knew...
    is it cold in chiTown already??
    man i wanna go there once
    got an elementary school frd livin' there
    2008 B7 A4 Quartz Gray 2.0T Quattro 6-spd MT.
    Full S-Line | Special Edition | Technology Package | HomeLink
    ____The Last of B7._
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    well in MN we were at 7 degrees when i left work at 10:30pm.
    why do you have your a/c on with heat?
    The usual things!!
    Resistor Install
    Jul 04 2007
    because its air conditioning... and I want the condition of the air to be warmer than it currently is.
    Senior Member Three Rings B7 Projectile's Avatar
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Quote Originally Posted by Jmaak View Post
    Incorrect, the extra "fan" that you are hearing, is the cars system switching to recirculation mode to prevent the smell of the washer fluid from entering the cabin. The air ducts for the cabin are right in front of the wipers. Go see for yourself.
    2007 Ibis Audi A4 2.0TFSI Ti Package
    Vorsteiner CF Hood.APR K04.APR HPFP.AWE Exhaust.AWE FMIC.034 HFC.KW-V2 CO's.Forge DV.3000k HID Fogs.Smoked Tails.Custom Intake.Heatshield.CC Mod.35%Tint.Blacked Rings.RS4 Rear Sway Bar.Podi boost gauge.
    Ah...so many pedestrians, so little time...
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    We've got 22F feels like 6 right now in Central New York...
    Why would the recirculation cause more noise?
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    Quote Originally Posted by whartung View Post
    Because instead of pulling from the atmosphere it is pulling the air from the cabin, try for yourself. Put it on recirculation mode, then place it in the normal mode, wash your windshield and see.
    PS, Now I know why I moved down to South Carolina, its about 50* here and im getting ready for a nice round of 18.
    Apr 18 2008
    Jacksonville, FL
    because with non-recirc, you're only pushing air into the car through the vents, ie. one-way. with recirc, you're both pushing air into the cabin AND pulling it out again, thereby using more vents & ducts, creating more air turbulence which creates more noise.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Veteran Member Three Rings ItsThat2.0T's Avatar
    Oct 28 2007
    Rhode Island
    Isn't AC considered the cold air?
    '07 Quattro A4 Brilliant Black
    | Premium Package | Carbonio CAI | 35% Tint | Trunk Lid Spoiler | REVO | VMR Vent Boost Gauge |
    2 Pedals.
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 26 2008
    Marysville, WA
    Quote Originally Posted by B7 Projectile View Post
    Interesting... I'm not sure it does that for me... at any rate, I always smell the stuff afterward.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    i thought that was b/c it was essentially temporarily turning on defrost (vents near the windshield) to prevent the wiper fluid from freezing on the windshield (cold temps) or something
    Senior Member Three Rings srsly's Avatar
    Jun 01 2008
    Long Island, NY
    that washer fluid stinks
    B8.5 Monsoon Grey A4 Previous: B8 Brilliant Black A5, B7 Brilliant Black A4
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    when you're defrosting, you want A/C, because the air is "dryer" than the ambient cabin air, which is already "humid", which is why the windows are fogging up to begin with
    (that and perhaps you and your passengers are a bunch of mouth breathers) :)
