Results 1 to 7 of 7
    Junior Member One Ring
    Mar 21 2007
    CA
    Car stalled suddenly on Highway-3.0L
    I probably posted this question on wrong section, so try this section--Thanks everyone.
    2002 A4 3.0L with 56K(miles).
    There were couple issues happened before it was stalled. Everthing happened with 20 to 30 mins from home to highway.
    At first, heat did not work and then entered into highway at the speed about 50miles for 2mins, coolant light came on right before it stalls. All electronics were working but It won't start after that and it need to be towed to dealer.
    I'm not looking for DIY, just want to get some idea OR What to expect?
    Coil pack???
    Thanks
    Jan 24 2007
    Re: Car stalled suddenly on Highway-3.0L
    how many miles on your car?? did you check the coolant reservior to see what cause the coolant light to come on??
    Mar 21 2007
    CA
    56K-2002
    I did, it was too dark for to see, no flashlight. There was a burning smell for sure. The coolant light came on and last less 5 seconds before it stalls. There were no signs before that expect the heat was not working(blowing only cold air) and just happened tonight.
    Jan 24 2007
    Quote Originally Posted by pentelgo2000 View Post
    56K-2002
    What kind of burning smell??? If you smelled sweet burning smell that is the sign that you were burning coolant, so was it sweet smell or smell of oil burning??
    Mar 21 2007
    CA
    Quote Originally Posted by A4_Joe View Post
    Don't really remember, but more like the smell of oil burning.
    What are outcomes for either one?
    Thanks
    Jan 24 2007
    Thanks
    Only reason why I asked what kind of smell it was because you said coolant light came on. The coolant light came on probably because it was low or leaking. If you smell sweet burning smell that is the sign your burning coolant. But since you told me that it was more like oil burning, I'm not quite sure since i can't diagnois the vehicle without looking at it.
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    what was the coolant gauge doing? my guess would be a coolant leak (if level is low), thermostat, or water pump failure.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
