Results 1 to 18 of 18
    Senior Member Three Rings Cyrix9445's Avatar
    Dec 05 2006
    2004 S4, 1995 Wrangler
    Orlando, FL
    Power Sun Shade DIY
    I submitted this to the DIY section, but I has not been approved yet.
    Parts Required:
    Rear Shelf
    Power Sun Blind
    Power Sun Blind Control Module
    Screw for Sun Blind (Will be explained later in post)
    Connector to Sun Blind
    Sun Blind Button for Dash
    Connector to Button
    Around 15ft of 3 Conductor Wire (I'd say at least 16 gauge)
    10 amp Inline Fuse
    Tools Required:
    Torx Screw Driver
    Various Wiring Tools (crimper, stripper, ect)
    Estimated Time: 1-2 Hours
    Here is a picture of the sun blind and module
    You will need to couple the 3 conductor wire to the sun blind connector.
    First you will need to remove the old rear shelf, start by removing the speaker grill, it will just pop off, you can use a flat blade screw driver if you cannot get your fingers under it, once the grill is off, there are 4 torx screws holding down the shelf, remove these.
    Next, you will have to remove some interior pieces to get to the rear deck, first remove the upper trim panel.
    Next, remove both rear grab handles. Pull down the screw covers and remove the 2 torx screws.
    Now you will need to free the C-piller covers from the rear deck, they are held in by clips, so just pull them towards you and leave them loose. Remove the 4 torx screws pictured earlier. There also are about 4 clips that hold the rear shelf in, they are right behind the rear seats, just pull the shelf towards you to free them. Now you can remove the shelf. Have someone hold the C-piller covers up so that you do not scratch your old shelf on the way out.
    Now that the old shelf is out, route your cable along side the brake light cable and down behind the trunk lining. You can route this cable to the front of the car many ways, I already had an amplifier wire ran to the trunk, so I followed that same path, but the wires need to end up in the dash.
    Now you can re-install your brake light onto the new blind, and install your new sun blind equipped shelf in reverse order then reinstall your interior pieces.
    Next, plug in the sun shade and brake light, and attach the sun blind to the car chassis using the screw. You can use the genuine Audi part which can be ordered from the dealership, I however had the perfect screw in my screw cozy.
    Now you will need to power the blind, I ran a power cable (with 10 amp inline fuse) from the battery down to the drivers side kick panel, there is a also a good ground bolt here, you can test the blind by momentarily touching the trigger wire to the positive.
    That's pretty much the hardest part, I will add the installation of the button to this writeup soon.
    2004 Sauce4
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Re: Power Sun Shade DIY
    nice!
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Sweet. I think they are the coolest. I've always wanted this feature but didn't find a car with it. My windows are tinted here in Vegas, so I don't think I would need it now. Thanks for the write-up though.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Veteran Member Three Rings Audi05s4's Avatar
    Oct 17 2006
    Hockessin, DE
    pretty cool to bad my tint is dark enough that i dont need a sunshade
    daworldisyours.com/forum<----check it out!!!!
    Senior Member Two Rings 1.9TDI's Avatar
    Mar 03 2008
    Nogaro Blue B6 S4 6MT, Quartz Grey B7 A4 Quattro
    Orlando, FL
    ha, now I think our cars are literally identical.... nice
    Dec 05 2006
    Orlando, FL
    Quote Originally Posted by 1.9TDI View Post
    lol this is true
    2004 Sauce4
    Sep 19 2007
    seattle
    This is just awesome! Thank you for sharing.
    Veteran Member Three Rings ZachPDX's Avatar
    Jun 09 2008
    PDX
    I test drove a black 05 with this, was pretty sweet. Thanks for taking the time to make a DIY!
    05
    JHM SM/LW Flywheel + Stg3 clutch | JHM Piggy's | Milltek nonres | JHM Tune | JHM 4:1 Center Diff | Neuspeed 25mm Rear Sway | APR snub | Apikol Rear Diff | JHM SSTS | Vogtland GT's
    SomeGuyInAChair - "I'll be honest about why I signed up for a car forum without thorough knowledge of cars. I merely did a Google search with the following key words: "milf cougar forum advice help tips"
    Dec 05 2006
    Orlando, FL
    np guys
    2004 Sauce4
    Dec 26 2008
    STL
    Hey great write up man, and on my b-day as well!
    I just got an 05 S4 but it has no rear sunshade..Can you send me those pictures in email, as they are not showing up anymore..
    Mar 05 2013
    CA
    Bump. Has anybody else done an OEM power rear sunshade install?
    I scored an OEM kit for it cheap, but I'm now learning that supposedly there is a control module necessary as well. I believe it's job is to know what position the sunshade is in or something, and make it so that the dashboard button works as a toggle on/off (aka extend/retract) switch.
    441 907 491 A (C5 A6 part number)
    Unless, maybe the control module is glued to the underside of the sunshade decklid? I'll check.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Dont forget, the OE rear sun shade has exactly 23 uses before it breaks.....Use incognito mode wisely. I think I have about 4 uses left =)
    Hey it's better then the pop out cup holder. Those are designed for only 16 1/2 uses before they break.
    B6 S4, B8 A4, 8P A3, and something, something.
    Feb 18 2014
    Arizona
    my car came with the rear sunshade, it's pretty cool. i've had an issue with it for a while now though, it won't go back down by itself anymore. it seems like there is too much friction and it gets stuck after it starts to go down. I haven't gotten around to looking at it to find the sticking point and add a little grease, I imagine that's probably all it needs but does anyone have experience doing this?
    Veteran Member Three Rings raswin's Avatar
    Feb 06 2009
    2002 Silver Audi B5 S4 Avant & a 99 Silver Audi A4 B5 Avant
    Davie, FL
    Yeah i would love to know myself. I have a 2005.5, and mine is stuck in the up position, i would love to get it fixed. Since it has been broken, i've been unable to tint the rear glass. And do i need it, i live in sunny Miami Florida..
    Veteran Member Four Rings Datadatum's Avatar
    Mar 12 2013
    Jax, FL
    Mine refuses to work when the car has been sitting in the sun. Kind of ironic...
    Feb 18 2014
    Arizona
    I have been able to make it go down manually, thanks to the fact that there is a delay between the time you hit the button and the time the little motor tries to pull the sunshade down. so if you get in the back seat, reach forward to hit the button, and then lean back again as quick as possible and push down on the shade to give it some assistance then it'll go down. If anyone has any tips on how to actually fix it, that would be great though
    Mar 05 2013
    CA
    Quote Originally Posted by RPMtech147 View Post
    So I found out that the control module IS a part of the sunshade assembly, and its on the underside. I believe it is the little black plastic box.
    Seriously though? Is it that unreliable? I got it for super cheap, so....
    At least the manual OEM rear door card shades I got with it, can't fail because its manual...
    I know of other luxury make/model cars with sunshades, and theirs have had absolutely zero problems even with high mileages..
    All of the other electric luxury stuff in my B6 has made it to 100k, so I'm hoping this will work too...For example, my memory power heated seats, auto-dimming rear-view mirror, and auto-folding reverse function mirrors (one tilts down when you reverse, to help see the curb when parallel parking)...
    I'm not sure if this is a fix for the sunshade issues you guys have been having, but I couldn't help but notice the modification in the junkyard car. I looked under the sunshade/deck-lid before I pulled it from the car, and there were 3 balled up old T-shirts crammed underneath. One in center, and one per corner. My guess to why the previous owner did this, is because the huge weight of the sunshade assembly makes the fragile weak thin cardboard decklid material deform. I imagine that would alter the angle of the sunshade. What do you think?
    Dec 26 2008
    STL
    oh wow, thread brought back to life from 2008! lol
