Results 1 to 28 of 28
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    APR Stage 2 dyno'd: 268HP - 333TQ
    Car: 2006 MT6 Quattro with 38k mi.
    Mods: APR93, Carbonio, Abt axleback converted to catback (2.5" pipe & highflow magnaflow res.)
    Fuel: Chevron 94
    Dyno: Dynapack
    Drivetrain loss: 28%
    193 AWHP @ 85MPH, 4,884RPM
    240 AWTQ @ 54MPH, 3,126RPM
    APR claims 266HP & 317TQ for stage 2 (APR93 + Carbonio + APR catback) on the same dyno using the same drivetrain loss number. I'm pretty happy with the results.
    Black B7 Titanium - Sold
    APR93 | Carbonio | Vogtlands | RS4 sway | Abt quad-tip | Podi | BBS RCs w/RT-615s | RS6s w/W300s
    Jul 04 2007
    Anchorage, AK / Chicago, IL
    Re: APR Stage 2 dyno'd: 268HP - 333TQ
    Your peak HP is at 4.8k? That doesn't sound right even with our tiny turbos...
    Senior Member Two Rings montess2001's Avatar
    Jan 20 2008
    Westchester, NY
    you are running stage 2 with stock cat?
    Current: 2015 SQ5 / 2016 ATS-V 6MT
    Mods: 034 Stg I + TCU / H&R+B8 / Neuspeed Rse103 20x9.5 et 25 / Carlinkit
    Previous: 8V S3 Daytona launch ed. / E92 M3 6MT / E39 M5 / B7 A4 Ibis 6MT Ti big turbo.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    numbers look good. magnaflow makes a highflow resonator?
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    numbers on the title corrected for the crank im guessing? if that so, i make almost that to the wheel, you should upgrade the fuel pump, and get the software for
    EDIT: just saw u had APR, nevermind about the file, wont do much
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Something that bothers me about this type of dynos, is that they don't take in to account the weight of the wheel. Say each wheel is 22lbs x 4 = 88 Lbs. 88 lbs that no longer have to be spun.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Quote Originally Posted by Ih8OEM View Post
    FWD (+ ~10%) plus extra supporting mods is why that is so.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Nov 27 2006
    High point, NC
    Quote Originally Posted by HID View Post
    Someone better tell Dinan, Apex, APR, TRD ect ect...
    They eliminate variables
    Dec 01 2007
    Markham, Ontario
    great numbers =) i have a similar setup, hopefully i have near those numbers
    btw do you know if APR Stage I file and so-called Stage II file are the same ?
    2015 BMW M3 Alpine White
    2013 Phantom Black RS5
    2012 Audi TTRS Black / Black - Sold
    Plus One
    Gabriel
    3255 Highway 7 East Unit 159
    Markham Ontario
    Cellular sales / repairs / unlocking / flashing - PM if you need help with anything
    Dec 26 2007
    PNWR
    Thanks for all the comments and feedback guys.
    Quote Originally Posted by Jmaak View Post
    Peak power on the last and best of three runs was at 4,884. The first run peaked at 5,178 and the second at around 4,900 as well. Care to elaborate on your comment? Seems logical to me since our tiny turbos run out of breath at higher RPMs.
    Quote Originally Posted by montess2001 View Post
    Yes. According to APR, stage 2 is APR93 file, Carbonio and APR catback exhaust. Stage 2 does not include a TP...it couldn't since it's illegal.
    Quote Originally Posted by RedS-line View Post
    Thanks and yes. I don't know the model number but it looks like a hollow pipe wrapped in a layer of soundproofing core.
    Depends on what you're trying to achieve I guess. I wanted to know how much my car is making now vs. stock, what my car is making vs. what APR claims it should be making and to get a read of what it's making now before I upgrade to a FMIC and a true cold air intake. Since APR uses the same dyno, I couldn't of hoped for a better scenario to compare apples to apples. I also have two sets of wheels that have a weight difference of 6lbs/side and I'm glad I didn't bias my numbers based on the wheels I have mounted at the time of the dyno.
    Quote Originally Posted by evilgabbie View Post
    Thanks and yes, according to APR, Stage 2 is APR93 file (stage 1), intake and catback.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Numbers look good Louis. I'm curious to see the change once you get a FMIC, are you going to get the AWE one? That's where I am leaning towards. And are you ever going to add a testpipe?
    Dec 26 2007
    PNWR
    Thanks man. I'm not sure yeton the FMIC...AWE, GSG or custom build. I'm skipping the TP as my car is as loud as I want it.
    Aug 31 2007
    Miami
    Quote Originally Posted by Zebman View Post
    yeah you obviously didnt read my post correctly, he is making 268hp 333 tq, to the crank, and i make 260fwhp and 330fwtq. kinda pismal IMO
    IG | @fukn_fafa
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    u have meth/TP/fwd--- just from fwd or keeping and extra 20whp(give or take) meth(15-20whp) and TP(5-10 whp) so theres ur extra 50ish WHP right there...
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Aug 31 2007
    Miami
    Quote Originally Posted by audikid66 View Post
    i would have loved to get 15-20 horsepower off of meth, i dynoed the differnces, no gains, just more consistent runs without heatsoaking, same effect as a FMIC, and what everyone fails to realize is that my WHEEL numbers are his CRANK numbers, the ONLY performance mod he doesnt have that i do is a fuel pump, but he is stage 2 therefore he must have a TP, if i were to correct for MY crank numbers... it would roughly be...
    299 whp
    380 wtq
    this is corrected to FWD giving roughly 15% drive train loss as opposed to the 28% for quattro
    IG | @fukn_fafa
    Jun 13 2007
    Belmar,NJ
    are you tuned for meth? did you advance timing,adjust AFR,or up the boost? if not then of course you wont see any gains besides conistancy and lower IAT
    Past cars:
    Aug 31 2007
    Miami
    i stand corrected, i up'd timing 1 POINT, i dont think that still accounts for the massive difference
    IG | @fukn_fafa
    Jun 13 2007
    Belmar,NJ
    im sure you can up timing more to get more power... but no i agree that is a 65 whp difference... but like i said also.. u have fwd and a TP(he doesnt have a TP) and you have revo software he has apr(apr is conservative) and ur fuel pump and you have meth (even tho u say u have no power gains..still ur car is running better with cooler IATs) so from what i see you have a very good running setup and his setup is a lil more conservative... were u guys on the same dyno? that makes a difference also... too many factors to even compare
    Past cars:
    Aug 31 2007
    Miami
    it was a different dyno and i couldnt up the timing anymore, i ran logs and im already at the safe limit for timing being pulled, and also if he has stage two he has to have a TP, there is no way around that, and as far as apr being conservative, i think that is a false statement, because when i first decided to gowith APR software, it was because of the dyno results and because APR offered the most power, now i decided to switch to revo because of the tunability (since i will soon have nitrous) and because the APR file is garbage (at least on my car)
    IG | @fukn_fafa
    Jun 13 2007
    Belmar,NJ
    sweet... nitrous is popular with u b7 guys it seems.. i guess ur blocks are built real strong.?
    Past cars:
    Aug 31 2007
    Miami
    nooo LOL. The blocks are garbage... It's just nitrous is probably the safest way to reach it's limit (if done properly of course) because if you bt it up that high you will blow. (not sure why, but I'll take that advice since nos is cheaper haha)
    IG | @fukn_fafa
    Active Member Four Rings Goped220's Avatar
    Feb 16 2006
    2023 Audi S4, 2023 Audi A4 & 2016 Subaru Crosstrek
    NY/FL
    When I dynoed my cars on a Dynojet I did 220 Horse power and 263 Torque, SAE Uncorrected wheel horse power. I am yet to dyno it will the apr fuel pump and software map.
    Previous:
    2006 Audi A4 Stage 3 6-Spd, 2011 Audi S4 6-Spd, 2016 Audi S4 6-Spd, 2017 Audi A4 6-Spd Stage 2, 2019 Audi S4 Stage 1, 2019 Benz E450 Stage 1, 2015 STI, 2013 370Z, 2013 Benz GLK, 2014 F-150 FX-4, 2020 Lexus GS350 F-Sport
    Dec 26 2007
    PNWR
    Thanks for all the posts guys. As stated above, I'm comparing apples to apples here. APR uses a Dynapack and claims 266HP/317TQ on their stage 2 Quattro 2.0T B7. APR Stage 2is APR93 file, catback exhaust and carbonio intake only...not TP. I have those exact mods and dyno'd on the same Dynapack. My car puts out 2HP and 16HP more than what they claim and the difference could be due to my Abt exhaust vs. their APR exhaust, ambient temps or both. Bottom line...my numbers are in line with what they should be according to APR and that's all I care about and what I wanted to share.
    Aug 31 2007
    Miami
    Quote Originally Posted by Louis J. View Post
    Why would u have stage 2 with out a test pipe? Since apt stage 2 is basicly only a check engine light clear for the o2 sensors
    IG | @fukn_fafa
    Dec 26 2007
    PNWR
    Because I don't want to worry about passing emissions and I don't want my car to be any louder than it is now.
    Dec 25 2007
    '06 A4, 08 R6s
    Stage 2 has nothing to do with TP, you get a completely seperate file, appropriately named the TP file, to clear the resulting CEL.
    I want a TP, but I live 3 hours away from my tuner, which is why i'm hesitant until I get the fuel pump at the same time.
    2008 R6s
    Aug 31 2007
    Miami
    how silly of me to make assumptions on a file I had that specifily tested stage2 differences. With and without file on the dyno. I must be retarded or something.
    IG | @fukn_fafa
    Veteran Member Four Rings Great White's Avatar
    Oct 07 2008
    Pinarello Prince w/Record 10sp
    Raleigh, NC
    Nice numbers Louis, I'm thinking of getting the same set up, but I'm not set on the exhaust yet.
    Would you by any chance have any sound clips with taking off and cabin sound? The ones I found on youtube were all static.
