Originally Posted by
wheel366
What fluid did you use? I thought you could only use the Audi approved fluid and not normal ATF. I was gonna get some Amsoil ATF but Audi said I could'nt use it.
you can use normal ATF as long as you flush out all of the old (audi) stuff, if you mix it, the tranny will fail, or at least thats what the manufacturers say.
the only fluid that i believe is different is the chrysler ATF+4. reason why is Valvoline now makes a tranny fluid that is compatible with everything, mercon, Mercon V, mercon SP, Dextron 4, BMW, Audi, toyota, nissan, Hyundai SP2&3, etc etc
if all these fluids really were proprietary, I have a hard time believing that Valvoline of all the companies out there managed to reverse engineer over 8 different fluids, then come up with a one size fits all solution. Thats some pretty good chemical engineering worthy of a nobel prize or something, yet they can't reverse engineer Chrysler's ATF? to me, it dosn't add up.
