Results 1 to 4 of 4
Thread: Downpipe Issue
    Nov 09 2008
    Pittsburgh
    Downpipe Issue
    Hey Im looking for advice or tips or anything at this point how how to install a downpipe I got a brand new neuspeed exhaust for really cheap, and been trying to install it for hours I can seem to figure out how you bolt the cat to the downipe. All the old exhuast is already removed, and the cat but but I cant seem to wiggle any type of open ended wrench or socket with extenions to torque two of the three of the bolts in the wee little room of the transmission tunnel. Does it install as one piece from the top or you have to install the downpipe and cat seprately. Sorry for the long post, Im just out of ideals and only have tomorrow left to install it.
    Btw its Fwd 1.8T
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Downpipe Issue
    Install it seperately
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: Downpipe Issue
    on a quattro it's easier to install separately. You need to start all the bolts before tightening them. Hope that helps.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: Downpipe Issue
    just did this today. what a PITA. tighten the cat down first. i thought it would be easier with both of them having wiggle room but it isnt. tighten cat to turbo, then but bolts in from top side and set gasket in place so bolts hold it up. then wiggle the downpipe. it will be 100x easier with a second person who can tighten from the top while you hold a wrench on the bottoms. i will recommend a wobbly socket and a long extension and tighten from wheel well area and under car
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
