Results 1 to 36 of 36
Thread: AEB HEAD
    Dec 06 2008
    mexico
    AEB HEAD
    Hi, im new to the forum and had a doubt though ivwe been reading for a while i decided to register today.
    I see that alot of people use the AEB head because of its larger intake ports, but as i read here http://forums.vwvortex.com/zerothread?id=3883030 it says that the AEB head is a non VVT head. Doesnt this give you a disadvantage?
    Could i fit that into my 04 A4Q? And will it gain a noticeable advantage? APR stg 1.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Re: AEB HEAD
    VVT is only the tensioner assembly for the cam chain. You can put a VVT tensioner into a AEB if you want. It is an emissions thing that Audi/VW went to in the newer cars. It isnt like Honda's Vtec that allows more power at higher rpms since it switches cam lobes.
    And an AEB head isnt gonna help you with a stock car (me considering your car stock with it only being chipped).
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Dec 06 2008
    mexico
    Re: AEB HEAD
    Quote Originally Posted by A4 TSCHUSS View Post
    So i just install the tensioner i have in my old head into the AEB one and thats it? Or is it a special one? If its no prob could you send me a link to see what are we talking about.
    And i plan to get a larger turbo in a future. Thanks
    Apr 24 2005
    E55 AMG, CTS-V
    Re: AEB HEAD
    It is the unit on the very back of the head bolted to the top with a plug on it. The tensioner part is under the valve cover but the actuator part and plug you can see on the back of the head.
    You will need to get an Audi tensioner tool that compresses the tensioner so you can take the chain off and pull the cams out or you can do it without the tool by grabbing the cams as a whole assembly with the tensioner and take it out as one. It is a little more tricky to do that way but that is how I do it. There are little notches on the cam sprockets that point straight up to line up with an arrow on the cam caps right near the sprocket. You line those notches up and then from one notch on one cam to the other notch on the other cam you need to have 16 pins on the chain.
    ~David~
    CTS-V 9.6@148
    Dec 06 2008
    mexico
    Re: AEB HEAD
    I have the tool, what i want to know is if my cam chain tensioner will fit on the AEB head, or if i will have to buy a different one!
    Apr 24 2005
    E55 AMG, CTS-V
    Re: AEB HEAD
    they are identical besides having larger intake ports (aeb) and then the extra part on the tensioner (amb). Will go right in.
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: AEB HEAD
    Yes, you can make an AEB head have VVT, just add a VVT tensioner like David said.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: AEB HEAD
    Is possible to a AMB head on an AEB motor?
    My friend doesn't mind if I switch heads with his 1997
    -Sami-
    Apr 24 2005
    E55 AMG, CTS-V
    Re: AEB HEAD
    yes but you will need to get an sai block off plate from integrated engineering since the newer A4 came with the emissions pump stuff on it so there is a port on the back of the head that will need to blocked off on the AMB head when you put it on the AEB motor and then you will need to remove that stuff from your car.
    ~David~
    CTS-V 9.6@148
    Feb 19 2007
    Charleston, SC
    Re: AEB HEAD
    Yea I wrote up the DIY on the removal of all that junk so I yea, I don't have any of it anymore LOL
    So I won't running into any issues with a AMB VVT head on a nonVVT car?
    -Sami-
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: AEB HEAD
    Should not be an issue.
    Feb 19 2007
    Charleston, SC
    Re: AEB HEAD
    Quote Originally Posted by Issam@034 View Post
    Thanks. Also will my DBW throttle directly bolt up to the AEB intake manifold and viceversa (will his nonDBW thottle body directly bolt up to the AMB intake mani?)
    -Sami-
    Apr 24 2005
    E55 AMG, CTS-V
    Re: AEB HEAD
    no his dbc wont bolt up to amb persay. The throttle body will bolt up but there are holes on the aem where a bracket goes to hold the cable which arent on the amb. You will need to find a aeb mani for sale somewhere.
    ~David~
    CTS-V 9.6@148
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: AEB HEAD
    no his dbc wont bolt up to amb persay. The throttle body will bolt up but there are holes on the aem where a bracket goes to hold the cable which arent on the amb. You will need to find a aem mani for sale somewhere.
    true, you need to buy him the transition gasket and let him run his old AEB mani
    - Clint
    Established Member Two Rings dfaudi's Avatar
    Sep 19 2005
    michigan
    Re: AEB HEAD
    I just picked up an AEB head. I want to build it to rev higher safely (for my GT3076 setup :). What ive been told is that i really only need valve springs.
    Is it worth doing the exhaust valves too?
    Do i need new retainers, seats, valve oil seals if i just do the srings?
    Will the B6 AMB injectors work on the B5 AEB manifold? Is the only differnce in the injector impedance?
    ________________________
    2019: B6 2.1L stroker, 01e, gtx35, 2200cc e85, AEM Infinity - 629 wheel
    2020: B6 K-Swap in progress, 01e, Borg Warner s369 - goal: 1000 wheel
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: AEB HEAD
    Quote Originally Posted by dfaudi View Post
    You dont need anything besides springs. However, tops of valves have been known to come off destroying engines.
    The AMB injectors should work in the AEB mani although I can't confirm it. Usually the B5 IM doesn't need spacers but you might. The injector impedance is not difference but the flow and size are
    - Clint
    Sep 19 2005
    michigan
    Re: AEB HEAD
    Is it worth getting the titanium retainers? Is there purpose just to keep the inertia down?
    Mar 21 2006
    Lakeland, FL.
    Re: AEB HEAD
    The lighter the parts the less likely they to float.
    I'm back bitches!
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: AEB HEAD
    exactly, the momentum would be less in one direction so when it has to change direction its easier
    - Clint
    Sep 19 2005
    michigan
    Re: AEB HEAD
    Anyone know if REVO/Eurocode's GT30 file can delete the VVT cel? I just want to stick with the AEB tensioner if possible.
    Any thoughts on Eurospec 272 cams?
    Mar 21 2006
    Lakeland, FL.
    Re: AEB HEAD
    There's still no GT30 file AFAIK, and from what I hear is to stay away from Eurospec parts. Look into Cat cams.
    I'm back bitches!
    Sep 19 2005
    michigan
    Re: AEB HEAD
    Called Eurocode the other day.
    They said theyd be able to do all this for me:
    - GT3076R file (using ATP manifold) Boosting 20psi capable of 35 psi
    - 630cc Siemens
    - VR6 Maf (can also be mafless but they recommended maf)
    - SAI/02 delete
    - High Rev limiter to 8500 (must sign waiver)
    I forgot to ask them they could eliminate the VVT. Im also shying away from the VR6 maf. Seems like a restriction imho
    Sep 19 2005
    michigan
    Re: AEB HEAD
    I can get a set of Eurospec 268's at a good price.
    Why arent they recommended?
    Sep 19 2005
    michigan
    Re: AEB HEAD
    Quote Originally Posted by dirtybrd View Post
    I dont know much about cams. Which Cat cams do you recommend for my BAT setup? I just updated my sig.
    Mar 21 2006
    Lakeland, FL.
    Re: AEB HEAD
    I run the 3658s. If they say they have it they must.
    I'm back bitches!
    Sep 19 2005
    michigan
    Re: AEB HEAD
    I think i came across a thread where you were having issues with the timing on these cams or something, or maybe it was with the VVT...you get the issues resolved?
    Mar 21 2006
    Lakeland, FL.
    Re: AEB HEAD
    You may or may not be able to run VVT with the 3658's. Bob@QED told me they were never tested. Unfortunately, the only way to test them is the plug it in. If it work's great, if not, bent valves. There are no issues timing them, you align the arrows and notches with 16 links between. I just leave mine unplugged and will later sent the ECU out for the code delete. The VVT is only for @idle emissions anyway. It doesn't fuction like a Hondas does, though that'd be nice.
    I'm back bitches!
    Sep 19 2005
    michigan
    Re: AEB HEAD
    Id rather not run VVT especially if its only for idle. I can also reuse the AEB tensioner and leave my amb head in tact and make a couple of $ back from it.
    You work out the warm start issues?
    So basically if i keep the vvt unplugged ill only have a CEL? No drivability issues? Cause ive had my CEL on for the 02 sensor and im used to it. Doesnt bother me.
    Feb 26 2006
    Earth
    Re: AEB HEAD
    CAT 3652's
    Apr 24 2005
    E55 AMG, CTS-V
    Re: AEB HEAD
    but dont the 3652s have shitty bottom end and midrange power? Only good for say 5000+rpm, therefore the 3658s are a better choice?
    Wonder where my Schrick 252/260 cams would fit in. I might have to get a more aggresive set later.
    ~David~
    CTS-V 9.6@148
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: AEB HEAD
    ya but the 52s do make the power.. its all preference
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: AEB HEAD
    There is a feature within the ECU to adjust inter-cam timing using the VVT solenoid. Mark@ASP and I messed around with it when tuning my car. Unfortunately, the way it is set up it only works as an on/off switch and is difficult to control. I think, in the end, we wound up setting slightly retarded which gave me a little bit quicker turbo spool. Its not ideal but it is a feature that can be adjusted when you have access to every map within the ECU.
    However, to Chris' point... No one (to my knowledge) has tried running VVT with 3658s. I'm running 3651s with VVT.
    -Doug
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: AEB HEAD
    I even have problems running VVT on my 3651's. Thus the reason why I am not running VVT. VVT turns on/off on me at unusual times when I run it.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: AEB HEAD
    Quote Originally Posted by CO AVANT View Post
    Hey Jordan. My car was running flawlessly at 4,000ft the other week. Now I just gotta get 'her up near 6000-8000ft to see how it runs at even higher altitude.
    -Doug
    Feb 12 2004
    Everywhere
    Re: AEB HEAD
    I'm wondering if it's software related...
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: AEB HEAD
    Perhaps.
    We did tweak a lot of things with the VVT, SAI and idle.
    -Doug
