    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Buying coilovers/Ksport coilovers
    What does someone need to look for when buying a used set?
    Is it worth it to buy brand new and have the warranty?
    Oct 20 2007
    Re: Buying used coilovers
    I also found these: Ksport coilovers
    They seem very well built and are very adjustable in every way
    Key Features:
    36-way adjustable dampening
    Made from high quality 6061 Aluminum with T6 for increased hardness Compression/Rebound adjustable
    Adjustable spring perch for height adjustment
    Adjustable body allowing maximum suspension travel
    Pillow Ball Top Mount w/ adjustable camber (on select models)
    Monotube High Pressure Design reduces oil leakage
    Electroplated body for protection from corrosion and rust
    One Year Limited Warranty
    Aug 03 2008
    VA
    Re: Buying coilovers/Ksport coilovers
    Ksports are a racing/track coilover setup. Only buy them if you want a really really stiff setup. I say this because I had them and ended up selling them because they were way to stiff. :(
    Oct 20 2007
    Thank you for your input death. Hmmm it kind of felt weird saying that.
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by VTAudiA4 View Post
    foreal though, death is right, I've had ksports too, and they're acutaly worse than most other setups for the road because they're so stiff. The only place they're good is on the track.
