I got all vacuum system remove but SAI pump is still in place. How much PSI does it produce? is there a way where you can hook it up to boost lines with some kind of valve to create more pressure and run it constantly? I guess something like a little electric supercharger? would it help in times when turbo is not spooled up and maybe it will erase CEL. I know it sounds like you putting it back but without all extra vacuum line.
Did i confuse the monkey out of you?
