Results 1 to 10 of 10
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Who has the Avic D3?
    Thinking about putting in an Avic D3 this winter, just wondering who has them, what you think, and how was the install? Pics would be great.
    One last thing, Are you guys using the metra dash kits? How is the fitment with those and can you provide me with a like as to which kit you bought?
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    Re: Who has the Avic D3?
    I helped put a d3 into a buddies 01 a4 last winter. It looks at home in the dash and the Metra install kit was used. Only thing I wish could be changed is the d3, even with the outside ring on it, seems to sit a tad bit below the metra kit. it doesnt sit 100% flush. it might be something you could shim or fix, we didnt really mess with it other then the install.
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    I have a d3 with the metra dash kit from ebay had mine professionally installed and I love it!. Fitment is pretty good will post pics when I get home from work!
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    Does anyone have trouble with their FM radio working?
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Feb 15 2007
    marimont
    go with the avic f700bt or 900bt. It's alot better unit and has better features for cheaper.
    Oct 08 2005
    Orlando, FL
    Id say go for the D3!
    Dunno why they came out small but if you click on the pics they get bigger!
    Enjoy!
    Apr 28 2008
    Houston, TX
    ^^ That looks really sick... how much was the install just out of curiosity?
    Oct 08 2005
    Orlando, FL
    thanks! bout 200 ish
    sound advice
    dont suggest going there a lil pricey!
    Apr 28 2008
    Houston, TX
    So i just bought a f90bt instead of the d3... is this the wiring harness you guys are using?
    http://www.crutchfield.com/p_1207017...s.html?tp=2977
    Senior Member Two Rings A4-Achtung's Avatar
    Oct 01 2008
    2.8 B5 A4 Quattro
    Austin, Texas - Third Coast
    That freakin' bad i'm definitely adding this to my endless list of mods!
    2001.5 B5 A4 QTM - AVIC F700BT Mod'd 3.0 - GIAC-X Tune - Bailey DV36 - 3 in. TestPipe 2.5'' Back- Blacked Out Everything - 6000k DDM HID Headlights And Fogs - Slotted and Drilled Rotors - HAIL DAMAGE!!! -
