Results 1 to 7 of 7
    Oct 20 2008
    B7 A4 2.0
    Jax Fl
    how much vynil for window trim?
    hey, i am going to vynil off my chrome window strips. about how many feet should be needed? were have you guys order from? im also thinking about doing the front grill and filler plate, has anyone done that with success?
    Veteran Member Four Rings adub's Avatar
    Nov 20 2008
    spiders
    Orange County
    Re: how much vynil for window trim?
    damn, i have the same question... Someone answer pleeeease.
    -Andrew
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    this has been posted a few times... search it
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Metrodecals.com has a flat black that I used. I would suggest buying about 30 ft so you have plenty and some extra in case you mess something up. 30 ft should be plenty to cover the window trim, the trim around the grille, and the strip under the trunk. Search black vinyl and my name and you can find a little write-up that I did.
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Oct 20 2008
    B7 A4 2.0
    Jax Fl
    thats, that will help alot. did you remove the grill when u covered it?
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    ps, it's vinyl, not vynil
    not trying to be an ass, but it might screw things up when people try to do a search.
    Mar 07 2008
    Audi A4 B7
    VA
    No need to take the grille off. You just need to lift the hood and then you can cut around the outside of the whole grille with a box cutter.
