Results 1 to 4 of 4
    Established Member Two Rings Stevet05A8L's Avatar
    Aug 16 2008
    2005 A8L 4.2
    Santa Monica
    Staggered wheels on a A8L not a good idea? Why?
    I heard someone say that staggered wheels on a quattro is not a good idea, I can't see why do you know?
    I have been playing with the idea of changing wheels and I ran across someone who said it's not a good idea, please explain.
    Thanks
    Established Member Two Rings chuck z's Avatar
    Nov 16 2008
    Charlotte, NC
    Re: Staggered wheels on a A8L not a good idea? Why?
    The way I understand it; b/c of the AWD system staggered wheels/tires will spin at a different RPM thus putting undue stress on the drive train (front wheels/tires spinning at a different rate than the rears) where wheels/tires of the same size all theoretically spin at the same RPM. I guess you could size the tires in such a way that they are the same size front to back but it might look kinda silly b/c of the sidewall required to get them the same height?
    I heard that Lambo will actually void a warranty if they see a car with a staggered setup.
    Established Member Two Rings THM's Avatar
    Jun 06 2007
    Audi A6 4.2
    Chicago
    Quote Originally Posted by chuck z View Post
    R8 and lambos do have staggered wheels
    i know that murcielago has front 245/35r18 and rear 335/30r18
    you can run staggered until rolling diameter is the same
    i dont think audi a8 should run staggered its not r8 or lambo
    but if you want
    here is link to check rolling diameter http://www.miata.net/garage/tirecalc.html
    2000 a6 4.2
    Aug 16 2008
    2005 A8L 4.2
    Santa Monica
    Ok I understand rolling height but what about width? Will the extra weight on wider rims in the rear have any ill effect on the drivetrain?
