Results 1 to 6 of 6
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    potential clutch issue?
    so i took my car into a mechanic today and he took my car for a test drive to diagnose a problem i had (problem now fixed), but he also noted that my clutch takes a long time to disengage, as in you have to bring the pedal out a lot before you can get the car rolling. i always thought this was normal but he thinks my clutch is on its way out...
    any thoughts?
    two thousand two audi a-four quattro five speed
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    Re: potential clutch issue?
    I think the catch points usually are high in Audis. If you get a racing clutch usually the catch point is low like hondas.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Nope. Not an issue, my release point personally is super high for all the cars i have driven, except for a GT2.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Quote Originally Posted by got boost. View Post
    Except if you have a LWFW ...
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Normal for stock clutch seeing that the stock pressure plate is really soft so it doesn't take much pressure to push the fingers down. THe after market clutch kits engage much lower because they use a pressure plate that is stuffer so it takes more pressure to push the fingers, they also have "pre-load" pressure while the stock clutch does not.
    Jul 10 2008
    Kelowna BC
    alright thanks for the input guys...
    PHEW
