Results 1 to 12 of 12
    Jun 24 2008
    texas
    just got my s4, looking for some help with upgrades
    thanks for the info
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: just got my s4, looking for some help with upgrades
    *facepalm*
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Senior Member Three Rings therox182's Avatar
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    Jul 07 2007
    Tempe, AZ
    GT28s and built motor with supporting bolt ons = $$$$$$$$$$$$$$$$$$$$
    no offense, but unless you have 20 grand to spend or wait til the single turbo kit is out, you most likely won't make 600 at the wheels
    see the "edit" button? use it.. 3 consecutive posts are unneccesary.
    facepalmed because there is a TON of archived information at the tips of your fingers by using the search button. on this same topic.
    Veteran Member Three Rings Chknkatsu's Avatar
    Feb 08 2008
    2010 Wrangler Unlimited 6spd, bmx bike, 337 GTi (SOLD)
    Whitestone, NY
    You said it's going to be a everyday DD for about a year, so, you probably shouldn't start building your motor until you get another car...because it'll probably take you about a year depending on who does it and what you're doing, these things don't happen over night, and VERY lucky if it takes you only a month or two.
    And if you are going to go with GTs I think you should build your motor while you're doing that, why not, you have high miles on the car who knows how much it can take until something goes, and the motor will be out anyway. Can't compare KO4/RS6 hybrids to GT's btw, especially since you want ~600
    As for the heads the 2.8 is from the RS4, some people prefer to stick with the 2.7 heads.
    I haven't heard of any proven strokers yet for the 2.7 yet.
    ...what am I saying, I don't even drive a s4
    __________________________________________________ ______________________________________
    $4c@b
    "I like to hide behind my sunglasses and check out the underage girls."
    WGLYC
    S4SugarHips
    "my name isn't mike."
    Jul 07 2007
    Tempe, AZ
    there's strokers for it.. 3.0L is common
    well considering ASP's GT28 kit is $15,000 without a built motor, I'd say it'll add up to a pretty expensive tab.
    Jun 24 2008
    texas
    yea buying a kit is that expensive but y cant you piece one together
    i put one together for around 6000 that has gt2871r
    Jul 07 2007
    Tempe, AZ
    manifolds for them and all? fueling? tune? heads?
    Jun 24 2008
    texas
    not building the motor, just the turbos, fueling, manifolds, intercooler was from ebay, and some parts were used
    Jul 07 2007
    Tempe, AZ
    you won't get 600 wheel without building the motor (at least rods) or the valvetrain. 2871R's get into the sweet spot right as we redline. need to be able to rev higher to get 600whp on 28s
    Jun 24 2008
    texas
    ok see now this is the info i need before i go spending $$$$$$
    Jun 24 2008
    texas
    sent private mes.
