    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Wheel Offset Question
    I'll plead ignorance here. Does a wheel with a 30mm backspace sit further out towards the fender lip than a wheel with a 35mm backspace? What do the B6/B7 cars call for so that there isn't rubbing when lowered?
    I lowered my Avant this week and I want to go to 19" inch wheels on it, but I want to make sure that I don't run into clearance problems.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Re: Wheel Offset Question
    Quote Originally Posted by AudiOso View Post
    You are correct and a +35MM on 19X8.5" wheel will be perfect for you with a very aggressive stance
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Registered Member Three Rings Buegie's Avatar
    Sep 18 2007
    e90
    a wheel w/ an et of 30 will poke more than one with 35
    Veteran Member Four Rings Eddie Man's Avatar
    Nov 05 2004
    Detroit/Clarkston
    Depending on the tire size you go with either ET35 or ET38 will be good.
    I had ET35 on my 19"s with 245/35 and a drop and I rubbed a little.
    I'm sure with 235/40, there will be no rubbing.
    I switched to a ET38, same tire size and it was perfect.
    2006 S4 Avant
    dolphin gray | 6speed | alcantara | premium | cold | bose | sirius | navigation | bluetooth | parktronic | ebony | carbon fiber
    >>> Got Mods?
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Thanks guys... I appreciate the info.
