Results 1 to 14 of 14
    Senior Member Two Rings BryMFL's Avatar
    Apr 20 2007
    '02 Audi 1.8T Quattro
    Winter Haven, FL
    Question Which color Forge 007 Spring?
    Just got the new 007 DV in today and I'm wondering which color spring to run with a fully stock engine? green(installed), blue, or yellow?
    "BryMFL"
    Bryan Meeks
    "Quattro- It's like having your very own roller coaster ride!"
    Apr 20 2007
    Winter Haven, FL
    Re: Which color Forge 007 Spring?
    Also what are the metal spacer/plate looking things for?
    "BryMFL"
    Bryan Meeks
    Apr 20 2007
    Winter Haven, FL
    Never mind found everythign on the Forge website. I'll be sure to credit everyone who has read this with 30 seconds of their life back
    "BryMFL"
    Bryan Meeks
    Apr 07 2011
    First thread that came up in my search and it's unanswered so here it is.
    Click
    Green - 5-15 PSI
    Yellow - 15-23 PSI
    Blue - 23-30 PSI
    Red - 30 + PSI
    Dec 19 2007
    York, PA
    i had a forge splitter years ago that i sold for like $50 on here...and i got a 710N instead. lol, im a retard.
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    I love my splttr, just wish it was a bit louder. Maybe i can modify the cone. Or mill a new one with a smaller dia hole so it will be a louder pitch.
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    I bet your ECU doesn't love your splitter.
    Venting off all that measured air is confusing for it.
    How is your fuel trims?
    VW/Audi keys. MK4-MK5-Mk6-B5-B6-B7-B8-B8.5-TT-A3-A4-A5-A6-A7-A8-Beetle-Tiguan-Touareg- ETC... PM for details
    Cluster Adaptation, ECU Adapting, Component Protection, Module Coding, Immobilizer, Keys Cutting/Programming
    May 03 2009
    A4%20B6/B8
    Arizona
    Quote Originally Posted by f1torrents View Post
    Dave@Motoza said they were perfect. It doesn't vent off much.
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Why is it that NOONE is capable of searching for their own answers anymore? cutoma4 literally answered this same exact question in 2 separate threads today!
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
    Dec 19 2007
    York, PA
    you can change dump and recirc %
    Apr 07 2011
    Quote Originally Posted by Myst420 View Post
    LOL Myst, sorry for the confusion. This thread was from 2008 but when I searched for the answer in the other thread, this was the first one to come up in the search. Guess what, there was no answer so I figured I'd make it easier for anyone searching in the future to just leave the answer here. There seems to be a trend around here that threads get made, get answered on their own, and don't report back to the thread with the resolution. It's extremely annoying and it really aggravates me when I'm searching and always find unanswered threads.
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    LMAO....MY bad. I didn't even notice the dates....Good idea though! That way when someone does search, we don't see another new thread...
    02 A4 Quattro 1.8T
    Aug 26 2005
    Quote Originally Posted by BryMFL View Post
    Use the spring with the lowest stiffness, the green spring.
    Vorsprung durch Technik
    Apr 27 2012
    Guelph
    If you are using it in the stock orientation then you don't have to worry about boost pressure.
    The air will be hitting the side of the piston so it will never be able to open the valve.
    Wether that effects the sound I don't know.
