Results 1 to 7 of 7
    Nov 22 2008
    01.5 S4
    Michigan
    Fuse and Battery Light Problem
    Hay whats going on.....just driving my car one day and getting off the highway car beeps thinking oh whatever just gas....i look the battery light and a fuse light turns on....so i change the fuse and everytime i change the fuse they just keep poping and my radio lights dont work so has this happened to anyone before please tell me what did u do to fixx this problem thank you
    Aug 06 2008
    Canadia
    Re: Fuse and Battery Light Problem
    you have a short
    the B5 S4 is like the mafia... there is only one way out!
    Nov 22 2008
    01.5 S4
    Michigan
    how can i fix it?
    Aug 06 2008
    Canadia
    by finding the bad wire, you'll need the basics, a multimeter and a test light.
    Nov 22 2008
    01.5 S4
    Michigan
    yeah...thats what my brother said where would u guess that wire is?
    Nov 22 2008
    01.5 S4
    Michigan
    bump
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    I'm no expert, I'm just going off of what i learned in my auto electronics class this semester. Get the tools mentioned above. Be wary of a test light, cause it could make the airbags go off if you touch it directly to their wire (so I've been told and seen).
    Start from either the battery or where the problem shows up (the radio in your case based on first post) find the wire that has to do with illumination of radio and work your way back following that wire until you find the problem. Could be exposed wire, bad ground, etc. Look at all connections for the wire to make sure they are good. Again, this is based off of what I've learned in my class this semester.
    Obviously, you might have to remove the lower dash to follow the wire back.
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
